Datasheet ADG7421F (Analog Devices) - 7
DescriptionLow Voltage Fault Protection and Detection, 12 Ω RON, Dual SPST Switch
Pages / Page30 / 7 — ADG7421F. SPECIFICATIONS. Table 3. Parameter. +25°C. −40°C to +85°C. …
ADG7421F. SPECIFICATIONS. Table 3. Parameter. +25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. 1.8 V SINGLE SUPPLY
ADG7421F SPECIFICATIONS Table 3 Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 1.8 V SINGLE SUPPLY
Data Sheet
ADG7421F SPECIFICATIONS Table 3. Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
600 600 µA max ISS 180 µA typ 250 250 µA max
1.8 V SINGLE SUPPLY
VDD = 1.8 V ± 5%, VSS = 0 V and GND = 0 V, unless otherwise noted.
Table 4. Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = 1.71 V, VSS = 0 V Analog Signal Range VSS + 0.1 to V VDD − 0.1 RON 12 Ω typ VS = 0.1 V to 1.61 V, IS = 10 mA 15 19 23 Ω max RFLAT (ON) 0.005 Ω typ VS = 0.1 V to 1.61 V, IS = 10 mA 0.03 0.05 0.1 Ω max RMATCH (ON) 0.01 VS = 0.1 V to 1.61 V, IS = 10 mA 0.2 0.5 0.7 LEAKAGE CURRENTS VDD = 1.95 V, VSS = 0 V IS (Off) ±0.05 nA typ VS = 0.6 V to 1.65 V, VD = 1.65 V to 0.6 V ±0.2 ±1.0 ±14.0 nA max ±3.5 nA max −40°C to +105°C ID (Off) ±0.05 nA typ VS = 0.6 V to 1.65 V, VD = 1.65 V to 0.6 V ±0.2 ±1.0 ±14.0 nA max ±3.5 nA max −40°C to +105°C ID (On), IS (On) ±0.05 nA typ VS = 0.6 V to 1.65 V, VD = 1.65 V to 0.6 V ±0.3 ±1.5 ±15.0 nA max ±4.0 nA max −40°C to +105°C FAULT VT 0.1 V typ IS With Overvoltage ±120 µA typ VDD = 1.95 V, VSS = 0 V, GND = 0 V, VS = ±60 V Power Supplies Grounded or Floating ±100 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V, INx = 0 V or floating, VS = ±60 V ID With Overvoltage ±0.1 nA typ VDD = 1.95 V, VSS = 0 V, GND = 0 V, VS = ±60 V ±0.3 ±2.5 ±30 nA max Power Supplies Grounded ±0.1 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±60 V, INx = 0 V ±0.3 ±2.5 ±30 nA max Power Supplies Floating ±11 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±60 V, INx = 0 V DIGITAL INPUTS/OUTPUTS VINH 1.07 V min VINL 0.5 V max IINL or IINH 0.7 µA typ VIN = 0 V or 5 V 1 µA max CIN 5 pF typ VOL 0.4 V max IFF = 2 mA
analog.com Rev. 0 | 7 of 30
Document Outline Features Applications Companion Products Functional Block Diagram General Description Product Highlights Specifications 5 V Single Supply 3 V Single Supply 1.8 V Single Supply ±2.5 V Dual Supply Continuous Current per Channel, Sx or Dx, Two Channels On Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADG7421F ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD, VS RON RFLAT (ON) IS (Off) ID (Off) ID (On), IS (On) VINL VINH IINL, IINH CD (Off) CS (Off) CD (On), CS (On) CIN tON tOFF tDIGRESP tDIGREC tRESPONSE tRECOVERY Off Isolation Charge Injection −3 dB Bandwidth On Response Insertion Loss THD + N AC Power Supply Rejection Ratio (AC PSRR) VT Theory of Operation Switch Architecture ESD Performance Trench Isolation Overvoltage Fault Protection Power-On Protection Power-Off Protection Overvoltage Interrupt Flag Applications Information Power Supply Rails Power Supply Recommendations Power Supply Sequencing Protection Signal Range Intelligent Fault Detection Short Duration Fault Current Thermocouple Input Protection RTD Input Protection Switches in a Known State High Voltage Suppression Outline Dimensions Ordering Guide
