Datasheet ADG5401F (Analog Devices) - 4
DescriptionFault Protection, 6 Ω RON, SPST Switch with 0.6 kΩ Feedback Channel
Pages / Page32 / 4 — ADG5401F. Data Sheet. Parameter. +25°C −40°C to +85°C −40°C to +125°C …
File Format / SizePDF / 573 Kb
ADG5401F. Data Sheet. Parameter. +25°C −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments
ADG5401F Data Sheet Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
FAULT (ON S AND SFB PINS) VT 0.7 V typ Source Leakage Current, IS With Overvoltage ±55 µA typ VDD = 16.5 V, VSS = −16.5 V, GND = 0 V, VS = ±60 V Power Supplies Grounded or Floating ±11 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V, IN = 0 V or floating, VS = ±60 V Drain Leakage Current, ID With Overvoltage ±0.1 nA typ VDD = 16.5 V, VSS = −16.5 V, GND = 0 V, VS = ±60 V ±0.3 ±5 ±55 nA max Power Supplies Grounded ±0.1 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±60 V, IN = 0 V ±0.3 ±5 ±55 nA max Power Supplies Floating ±2 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±60 V, IN = 0 V DIGITAL INPUTS/OUTPUTS Input Voltage High, VINH 1.3 V min Input Voltage Low, VINL 0.8 V max Input Low or High Current, IINL or IINH 2.5 µA typ Input voltage (VIN) = 0 V or 5 V 5 µA max Digital Input Capacitance, CIN 5 pF typ Output Voltage Low, VOL 0.4 V max Fault flag current (IFF) = 2 mA DYNAMIC CHARACTERISTICS On Time, tON 14.2 µs typ Load resistance (RL) = 300 Ω, load capacitance (CL) = 35 pF, VS = 10 V 17 17.2 17.2 µs max Off Time, tOFF 185 ns typ RL = 300 Ω, CL = 35 pF, VS = 10 V 220 220 220 ns max Overvoltage Response Time, tRESPONSE Positive 230 ns typ RL = 1 kΩ, CL = 5 pF 230 240 240 ns max Negative 0.8 µs typ RL = 1 kΩ, CL = 5 pF 1 1.1 1.2 µs max Overvoltage Recovery Time, tRECOVERY 11.7 µs typ RL = 1 kΩ, CL = 5 pF 14.4 14.5 14.5 µs max Interrupt Flag Response Time, tDIGRESP 80 ns typ Pull-up resistor (RPULLUP) = 1 kΩ, CL = 12 pF, pull-up voltage (VPULL_UP) = 5 V 90 95 100 ns max Interrupt Flag Recovery Time, tDIGREC 1.5 µs typ RPULLUP = 1 kΩ, CL = 12 pF, VPULL_UP = 5 V 2 2.2 2.2 µs max Charge Injection, QINJ −230 pC typ VS = 0 V, source resistor (RS) = 0 Ω, CL = 1 nF Rev. 0 | Page 4 of 32 Document Outline FEATURES APPLICATIONS COMPANION PRODUCTS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADG5401F ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation OVERVOLTAGE FAULT PROTECTION Power-On Protection Power Off Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY RECOMMENDATIONS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE OUTPUT CHANNEL PROTECTION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS AMPLIFIER OR DAC OUTPUT PROTECTION OPEN-LOOP PREVENTION POWER-ON CONDITION SWITCHES IN A KNOWN STATE HIGH VOLTAGE SURGE SUPPRESSION OUTLINE DIMENSIONS ORDERING GUIDE
