Data SheetADG5401FParameter+25°C−40°C to +85°C−40°C to +125°CUnitTest Conditions/Comments ID With Overvoltage ±0.1 nA typ VDD = 22 V, VSS = −22 V, GND = 0 V, VS = ±58 V ±0.3 ±5 ±55 nA max Power Supplies Grounded ±0.1 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±60 V, IN = 0 V ±0.3 ±5 ±55 nA max Power Supplies Floating ±2 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±60 V, IN = 0 V DIGITAL INPUTS/OUTPUTS VINH 1.3 V min VINL 0.8 V max IINL or IINH 2.5 µA typ VIN = 0 V or 5 V 5 µA max CIN 5 pF typ VOL 0.4 V max IFF = 2 mA DYNAMIC CHARACTERISTICS tON 15.9 µs typ RL = 300 Ω, CL = 35 pF, VS = 10 V 19.1 19.3 19.4 µs max tOFF 180 ns typ RL = 300 Ω, CL = 35 pF, VS = 10 V 210 220 220 ns max tRESPONSE Positive 230 ns typ RL = 1 kΩ, CL = 5 pF 230 230 230 ns max Negative 0.7 µs typ RL = 1 kΩ, CL = 5 pF 0.9 0.9 1 µs max tRECOVERY 13.8 µs typ RL = 1 kΩ, CL = 5 pF 16.8 16.9 16.9 µs max tDIGRESP 80 ns typ RPULLUP = 1 kΩ, CL = 12 pF, VPULL_UP = 5 V 90 95 100 ns max tDIGREC 1.9 µs typ RPULLUP = 1 kΩ, CL = 12 pF, VPULL_UP = 5 V 2.4 2.6 2.6 µs max QINJ −270 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF Off Isolation −70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz THD + N 0.001 % typ RL = 10 kΩ, VS = 10 V p-p, f = 20 Hz to 20 kHz −3 dB Bandwidth 450 MHz typ RL = 50 Ω, CL = 5 pF Insertion Loss −0.5 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz CS (Off) 8 pF typ VS = 0 V, f = 1 MHz CD (Off) 10 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 18 pF typ VS = 0 V, f = 1 MHz Rev. 0 | Page 7 of 32 Document Outline FEATURES APPLICATIONS COMPANION PRODUCTS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADG5401F ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation OVERVOLTAGE FAULT PROTECTION Power-On Protection Power Off Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY RECOMMENDATIONS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE OUTPUT CHANNEL PROTECTION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS AMPLIFIER OR DAC OUTPUT PROTECTION OPEN-LOOP PREVENTION POWER-ON CONDITION SWITCHES IN A KNOWN STATE HIGH VOLTAGE SURGE SUPPRESSION OUTLINE DIMENSIONS ORDERING GUIDE
