Datasheet ADG5298 (Analog Devices) - 10
DescriptionHigh Temperature, High Voltage, Latch-Up Proof, 8-Channel Multiplexer
Pages / Page20 / 10 — ADG5298. Data Sheet. 700. VDD = 12V. +210°C. VDD = +20V. VSS = 0V. …
File Format / SizePDF / 570 Kb
ADG5298. Data Sheet. 700. VDD = 12V. +210°C. VDD = +20V. VSS = 0V. +175°C. VSS = –20V. 600. +125°C. VBIAS = +15V, –15V. +85°C. +25°C. –40°C. ) 500
ADG5298 Data Sheet 700 VDD = 12V +210°C VDD = +20V VSS = 0V +175°C VSS = –20V 600 +125°C VBIAS = +15V, –15V +85°C +25°C –40°C ) 500
ADG5298 Data Sheet 700 10 VDD = 12V +210°C VDD = +20V VSS = 0V +175°C VSS = –20V 600 +125°C VBIAS = +15V, –15V +85°C 0 +25°C –40°C ) 500 –55°C A) (n ( –10 NT 400 RE TANCE –20 IS S CUR 300 E AG N RE O AK –30 200 E I L S (OFF) + – ID (OFF) + – IS (OFF) – + 100 –40 ID (OFF) – + IS, ID (ON) + + IS, ID (ON) – – 0 –50 0 2 4 6 8 10 12
10 14 0
–55 –25 5 35 65 95 125 155 185 215
0 2- 2-
VS, VD (V)
487
TEMPERATURE (°C)
487 1 1 Figure 10. On Resistance (R Figure 13. Leakage Current vs. Temperature, ±20 V Dual Supply ON) as a Function of VS, VD for Various Temperatures, 12 V Single Supply
300 5 +210°C +175°C +125°C 0 250 +85°C +25°C –40°C –5 –55°C A) ) n ( (Ω 200 E NT –10 C N TA 150 –15 S CURRE E ESI R –20 N 100 O AKAG E I L S (OFF) + – –25 ID (OFF) + – IS (OFF) – + 50 –30 ID (OFF) – + VDD = 12V V I V DD = 36V S, ID (ON) + + SS = 0V V
1
I V SS = 0V
01
S, ID (ON) – – BIAS = 1V, 10V 0
2-
–35
5
0 4 8 12 16 20 24 28 32 36 –55 –25 5 35 65 95 125 155 185 215
487 01 1 2-
VS, VD (V) TEMPERATURE (°C)
87 14 Figure 11. On Resistance (RON) as a Function of VS, VD for Various Figure 14. Leakage Current vs. Temperature, 12 V Single Supply Temperatures, 36 V Single Supply
5 5 VDD = +15V VSS = –15V V 0 BIAS = +10V, –10V 0 –5 A) A) n –10 (n –5 ( NT NT –15 –10 –20 CURRE CURRE E E –25 –15 AKAG AKAG E I –30 E I L S (OFF) + – L S (OFF) + – ID (OFF) + – ID (OFF) + – –35 –20 IS (OFF) – + IS (OFF) – + ID (OFF) – + V I DD = 36V D (OFF) – + I –40 S, ID (ON) + + VSS = 0V IS, ID (ON) + + IS, ID (ON) – – VBIAS = 1V, 30V IS, ID (ON) – – –25 –45 –55 –25 5 35 65 95 125 155 185 215
13 22 0
0 2- 2-
TEMPERATURE (°C)
487
TEMPERATURE (°C)
487 1 1 Figure 12. Leakage Currents vs. Temperature, ±15 V Dual Supply Figure 15. Leakage Current vs. Temperature, 36 V Single Supply Rev. 0 | Page 10 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL-SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL (Sx OR D) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
