Datasheet ADG5243F (Analog Devices) - 4
DescriptionUser Defined Fault Protection and Detection, 0.8 pC QINJ, Triple SPDT
Pages / Page30 / 4 — ADG5243F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. …
File Format / SizePDF / 649 Kb
ADG5243F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG5243F Data Sheet −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
link to page 23 link to page 23 link to page 23 link to page 22 link to page 21 link to page 21 link to page 21 link to page 22 link to page 22 link to page 23 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20
ADG5243F Data Sheet −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 160 ns typ RL = 1 kΩ, CL = 35 pF 195 210 215 ns max VS = 10 V, see Figure 47 tON (EN) 165 ns typ RL = 1 kΩ, CL = 35 pF 205 220 230 ns max VS = 10 V, see Figure 46 tOFF (EN) 70 ns typ RL = 1 kΩ, CL = 35 pF 90 110 110 ns max VS = 10 V, see Figure 46 Break-Before-Make Time Delay, tD 115 ns typ RL = 1 kΩ, CL = 35 pF 85 ns min VS = 10 V, see Figure 45 Overvoltage Response Time, tRESPONSE 90 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 40 115 130 130 ns max Overvoltage Recovery Time, tRECOVERY 745 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 41 945 965 970 ns max Interrupt Flag Response Time, tDIGRESP 90 ns typ CL = 12 pF, see Figure 42 Interrupt Flag Recovery Time, tDIGREC 65 µs typ CL = 12 pF, see Figure 43 900 ns typ CL = 12 pF, RPULLUP = 1 kΩ, see Figure 44 Charge Injection, QINJ −0.8 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF, see Figure 48 Off Isolation −74 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 37 Channel-to-Channel Crosstalk −83 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 39 Total Harmonic Distortion Plus Noise, THD + N 0.005 % typ RL = 10 kΩ, VS = 15 V p-p, f = 20 Hz to 20 kHz, see Figure 36 −3 dB Bandwidth 350 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 38 Insertion Loss 10.5 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 38 CS (Off) 4 pF typ VS = 0 V, f = 1 MHz CD (Off) 4 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 10 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = POSFV = +16.5 V, VSS = NEGFV = −16.5 V, GND = 0 V, digital inputs = 0 V, 5 V, or VDD Normal Mode IDD 1.3 mA typ IPOSFV 0.15 mA typ IDD + IPOSFV 2 2.1 mA max IGND 0.75 mA typ 1.25 1.4 mA max ISS 0.65 mA typ INEGFV 0.2 mA typ ISS + INEGFV 0.95 1.0 mA max Fault Mode VS = ±55 V, all channels in fault IDD 1.4 mA typ IPOSFV 0.2 mA typ IDD + IPOSFV 2.5 2.8 mA max IGND 0.9 mA typ 1.8 1.9 mA max ISS 0.55 mA typ INEGFV 0.2 mA typ ISS + INEGFV 1.0 1.1 mA max VDD/VSS ±5 V min GND = 0 V ±22 V max GND = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 4 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation USER DEFINED FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
