Datasheet ADG5248F, ADG5249F (Analog Devices) - 10
DescriptionUser Defined Fault Protection and Detection, 0.8 pC QINJ, 8:1/Dual 4:1 Multiplexers
Pages / Page34 / 10 — ADG5248F/ADG5249F. Data Sheet. −40°C to. Parameter. +25°C +85°C. +125°C. …
File Format / SizePDF / 677 Kb
ADG5248F/ADG5249F. Data Sheet. −40°C to. Parameter. +25°C +85°C. +125°C. Unit. Test Conditions/Comments
ADG5248F/ADG5249F Data Sheet −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
link to page 21 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 27 link to page 26 link to page 26 link to page 26 link to page 24 link to page 25 link to page 11
ADG5248F/ADG5249F Data Sheet −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
On-Resistance Flatness, RFLAT(ON) 62 Ω typ VS = 0 V to 30 V, IS = −1 mA 70 85 100 Ω max 1.5 Ω typ VS = 4.5 V to 28 V, IS = −1 mA 3.5 4 4 Ω max Threshold Voltage, VT 0.7 V typ See Figure 30 LEAKAGE CURRENTS VDD = 39.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 36 ±1 ±2 ±5 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 36 ±1 ±5 ±10 nA max Channel On Leakage, ID (On), IS (On) ±0.3 nA typ VS = VD = 1 V/30 V, see Figure 37 ±1.5 ±20 ±25 nA max FAULT Source Leakage Current, IS With Overvoltage ±58 µA typ VDD = 39.6 V, VSS = 0 V, GND = 0 V, VS = +55 V, −40 V, see Figure 35 Power Supplies Grounded or ±25 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = Floating 0 V, Ax = 0 V or floating, VS = ±55 V, see Figure 34 Drain Leakage Current, ID With Overvoltage ±10 nA typ VDD = 39.6 V, VSS = 0 V, GND = 0 V, VS = +55 V, −40 V, see Figure 35 ±50 ±70 ±90 nA max Power Supplies Grounded ±500 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±55 V, Ax = 0 V, see Figure 34 ±700 ±700 ±700 nA max Power Supplies Floating ±50 ±50 ±50 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±55 V, Ax = 0 V, see Figure 34 DIGITAL INPUTS Input Voltage High, VINH 2.0 V min Low, VINL 0.8 V max Input Current, IINL or IINH ±0.7 µA typ VIN = VGND or VDD ±1.1 ±1.2 µA max Digital Input Capacitance, CIN 5.0 pF typ Output Voltage High, VOH 2.0 V min Low, VOL 0.8 V max DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 195 ns typ RL = 1 kΩ, CL = 35 pF 255 275 285 ns max VS = 18 V, see Figure 50 tON (EN) 190 ns typ RL = 1 kΩ, CL = 35 pF 245 270 280 ns max VS = 18 V, see Figure 49 tOFF (EN) 105 ns typ RL = 1 kΩ, CL = 35 pF 135 145 145 ns max VS = 18 V, see Figure 49 Break-Before-Make Time Delay, tD 110 ns typ RL = 1 kΩ, CL = 35 pF 60 ns min VS = 18 V, see Figure 48 Overvoltage Response Time, tRESPONSE 60 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 43 80 85 85 ns max Overvoltage Recovery Time, tRECOVERY 1400 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 44 1900 2100 2200 ns max Rev. A | Page 10 of 34 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx, D, OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation USER DEFINED FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
