Datasheet ADG5436F (Analog Devices) - 10
DescriptionFault Protection and Detection, 10 Ω RON, Dual SPDT Switch
Pages / Page30 / 10 — ADG5436F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. …
RevisionC
File Format / SizePDF / 669 Kb
ADG5436F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG5436F Data Sheet −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
link to page 23 link to page 23 link to page 23 link to page 23 link to page 21 link to page 21 link to page 22 link to page 22 link to page 22 link to page 23 link to page 20 link to page 20 link to page 21 link to page 20 link to page 20
ADG5436F Data Sheet −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 400 ns typ RL = 300 Ω, CL = 35 pF 540 555 570 ns max VS = 10 V, see Figure 46 tON (EN) 440 ns typ RL = 300 Ω, CL = 35 pF 520 540 560 ns max VS = 18 V, see Figure 45 tOFF (EN) 160 ns typ RL = 300 Ω, CL = 35 pF 190 195 200 ns max VS = 18 V, see Figure 45 Break-Before-Make Time Delay, tD 330 ns typ RL = 300 Ω, CL = 35 pF 210 ns min VS = 18 V, see Figure 44 Overvoltage Response Time, tRESPONSE 260 ns typ RL = 1 kΩ, CL = 2 pF, see Figure 39 340 360 385 ns max Overvoltage Recovery Time, tRECOVERY 1500 ns typ RL = 1 kΩ, CL = 2 pF, see Figure 40 2100 2400 2700 ns max Interrupt Flag Response Time, tDIGRESP 85 115 ns typ CL = 12 pF, see Figure 41 Interrupt Flag Recovery Time, tDIGREC 60 85 µs typ CL = 12 pF, see Figure 42 600 ns typ CL = 12 pF, RPULLUP = 1 kΩ, see Figure 43 Charge Injection, QINJ −627 pC typ VS = 18 V, RS = 0 Ω, CL = 1 nF, see Figure 47 Off Isolation −71 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 33 Channel-to-Channel Crosstalk −73 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 34 Total Harmonic Distortion Plus Noise, THD + N 0.001 % typ RL = 10 kΩ, VS = 18 V p-p, f = 20 Hz to 20 kHz, see Figure 38 −3 dB Bandwidth 173 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 37 Insertion Loss −0.8 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 37 CS (Off) 11 pF typ VS = 18 V, f = 1 MHz CD (Off) 23 pF typ VS = 18 V, f = 1 MHz CD (On), CS (On) 36 pF typ VS = 18 V, f = 1 MHz POWER REQUIREMENTS VDD = 39.6 V, VSS = 0 V, digital inputs = 0 V, 5 V, or VDD Normal Mode IDD 0.9 mA typ 1.2 1.3 mA max IGND 0.4 mA typ 0.55 0.6 mA max ISS 0.5 mA typ 0.65 0.7 mA max Fault Mode VS = +55 V, −40 V IDD 1.2 mA typ 1.6 1.8 mA max IGND 0.8 mA typ 1.0 1.1 mA max ISS 0.5 mA typ Digital inputs = 5 V 1.0 1.8 mA max VS = ±55 V, VD = 0 V VDD 8 V min GND = 0 V 44 V max GND = 0 V 1 Guaranteed by design. Not subject to production test. Rev. C | Page 10 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sxx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLES FOR SWITCHES TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE CHANNEL PROTECTION POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
