Datasheet ADG5419 (Analog Devices) - 10
Description | High Voltage Latch-Up Proof, Single SPDT Switch |
Pages / Page | 19 / 10 — ADG5419. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. VDD = … |
Revision | A |
File Format / Size | PDF / 316 Kb |
ADG5419. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. VDD = +9V. VDD = +10V. VSS = –9V. VSS = –10V. VDD = +11V. VSS = –11V
ADG5419 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 25 16 T T A = 25°C A = 25°C VDD = +9V VDD = +10V 14 VSS = –9V VSS = –10V 20 12 ) VDD = +11V ) Ω Ω ( VSS = –11V ( 10 15 CE CE TAN TAN V 8 DD = 32.4V V V DD = 36V DD = 39.6V IS IS VSS = 0V V V S S SS = 0V SS = 0V 10 VDD = +13.5V 6 N RE V N RE O SS = –13.5V VDD = +15V V V O DD = +16.5V SS = –15V VSS = –16.5V 4 5 2 0 0 –18 –14 –10 –6 –2 2 6 10 14 18 0 5 10 15 20 25 30 35 40 45 –16 –12 –8 –4 0 4 8 12 16
003 006
V
70- 70-
S, VD (V) V
13
S, VD (V)
13 1 1 Figure 5. On Resistance as a Function of VS, VD Dual Supply Figure 8. On Resistance as a Function of VS, VD (Single Supply)
16 25 TA = 25°C 14 V 20 12 DD = +18V V ) SS = –18V ) T Ω Ω A = +125°C ( E ( 10 C 15 CE TA = +85°C N TA 8 TAN S V V DD = +20V DD = +22V T V V IS A = +25°C SS = –20V SS = –22V S ESI 10 R 6 N N RE TA = –40°C O O 4 5 2 VDD = +15V VSS = –15V 0 0 –25 –20 –15 –10 –5 0 5 10 15 20 25 –15 –10 –5 0 5 10 15
004 007
V
70- 70-
S, VD (V) V
13
S, VD (V)
13 1 1 Figure 6. On Resistance as a Function of VS, VD Dual Supply) Figure 9. On Resistance as a Function of VS (VD) for Different Temperatures, ±15 V Dual Supply
35 25 TA = 25°C VDD = +20V V V DD = 10V SS = –20V 30 VSS = 0V VDD = 10.8V VSS = 0V VDD = 9V 20 VSS = 0V 25 ) ) Ω Ω ( E ( CE 15 T 20 C A = +125°C N TAN T V TA A = +85°C IS DD = 11V S S V 15 SS = 0V VDD = 12V ESI T V 10 A = +25°C SS = 0V VDD = 13.2V R N RE V N O SS = 0V O T 10 A = –40°C 5 5 0 0 0 2 4 6 8 10 12 14
005
008
VS, VD (V)
370- 70- 1 1
VS, VD (V)
13 1 Figure 7. On Resistance as a Function of VS, VD (Single Supply) Figure 10. On Resistance as a Function of VS (VD) for Different Temperatures, ±20 V Dual Supply Rev. A | Page 10 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
