Datasheet ADG5421, ADG5423 (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, Dual SPST Switches
Pages / Page17 / 5 — Data Sheet. ADG5421/ADG5423. 12 V SINGLE SUPPLY. Table 3. Parameter. …
File Format / SizePDF / 402 Kb
Data Sheet. ADG5421/ADG5423. 12 V SINGLE SUPPLY. Table 3. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit
Data Sheet ADG5421/ADG5423 12 V SINGLE SUPPLY Table 3 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 14 link to page 13 link to page 13 link to page 13
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 26 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 25 30 38 44 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between 0.1 Ω typ VS = 0 V to 10 V, IS = −10 mA Channels, ∆RON 1 1.5 1.6 Ω max On-Resistance Flatness, RFLAT (ON) 5.5 Ω typ VS = 0 V to 10 V, IS = −10 mA 6.8 8.3 12.3 Ω max LEAKAGE CURRENTS VDD = +13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = 1 V to 10 V, VD = 10 V to 1 V; see Figure 24 ±0.25 ±1 ±10 nA max Drain Off Leakage, ID (Off) ±0.05 nA typ VS = 1 V to 10 V, VD = 10 V to 1 V; see Figure 24 ±0.25 ±1 ±10 nA max Channel On Leakage, ID (On), IS (On) ±0.1 nA typ VS = VD = 1 V to 10 V; see Figure 23 ±0.4 ±4 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 6 pF typ DYNAMIC CHARACTERISTICS1 tON 295 ns typ RL = 300 Ω, CL = 35 pF 370 470 540 ns max VS = 8 V; see Figure 30 tOFF 192 ns typ RL = 300 Ω, CL = 35 pF 235 273 295 ns max VS = 8 V; see Figure 30 Break-Before-Make Time Delay, tD 142 ns typ RL = 300 Ω, CL = 35 pF (ADG5423 Only) 78 ns min VS1 = VS2 = 8 V; see Figure 32 Charge Injection, QINJ 55 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 31 Off Isolation −55 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Channel-to-Channel Crosstalk −85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Total Harmonic Distortion + Noise 0.03 % typ RL = 1 kΩ, 6 V p-p, f = 20 Hz to 20 kHz; see Figure 27 −3 dB Bandwidth 290 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 28 Insertion Loss −1.7 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 CS (Off) 14 pF typ VS = 6 V, f = 1 MHz CD (Off) 15 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) 38 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 5 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
