Datasheet ADG5204 (Analog Devices) - 5
DescriptionHigh Voltage, Latch-up Proof, 4-Channel Multiplexer
Pages / Page20 / 5 — ADG5204. 12 V SINGLE SUPPLY. Table 3. Parameter. 25°C. −40°C to +85°C. …
RevisionA
File Format / SizePDF / 314 Kb
ADG5204. 12 V SINGLE SUPPLY. Table 3. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C Unit. Test. Conditions/Comments
ADG5204 12 V SINGLE SUPPLY Table 3 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 14 link to page 14 link to page 14 link to page 14 link to page 5
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V max On Resistance, RON 340 Ω typ VS = 0 V to 10 V, IS = −1 mA, see Figure 24 500 610 700 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match 5 Ω typ VS = 0 V to 10 V, IS = −1 mA Between Channels, ∆RON 20 21 22 Ω max On-Resistance Flatness, RFLAT(ON) 145 Ω typ VS = 0 V to 10 V, IS = −1 mA 280 335 370 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) 0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 23 0.1 0.2 0.4 nA max Drain Off Leakage, ID (Off) 0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 23 0.1 0.4 2.4 nA max Channel On Leakage, ID, IS (On) 0.02 nA typ VS = VD = 1 V/10 V, see Figure 26 0.2 0.5 2.8 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 240 ns typ RL = 300 Ω, CL = 35 pF 350 445 515 ns max VS = 8 V, see Figure 29 tON (EN) 250 ns typ RL = 300 Ω, CL = 35 pF 335 420 485 ns max VS = 8 V, see Figure 31 tOFF (EN) 160 ns typ RL = 300 Ω, CL = 35 pF 195 220 240 ns max VS = 8 V, see Figure 31 Break-Before-Make Time Delay, tD 140 ns typ RL = 300 Ω, CL = 35 pF 60 ns min VS1 = VS2 = 8 V, see Figure 30 Charge Injection, QINJ −1.2 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF, see Figure 32 Off Isolation −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 25 Channel-to-Channel Crosstalk −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 28 −3 dB Bandwidth 106 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 27 Insertion Loss −11 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 27 CS (Off) 3.5 pF typ VS = 6 V, f = 1 MHz CD (Off) 29 pF typ VS = 6 V, f = 1 MHz CD, CS (On) 33 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 μA typ Digital inputs = 0 V or VDD 65 μA max VDD 9/40 V min/max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
