link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 8 ADG4612/ADG46135 V SINGLE SUPPLY VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted. Table 3. Parameter25°C−40°C to +85°CUnitTest Conditions/Comments ANALOG SWITCH Analog Signal Range −5.5 V to VDD V VDD to VSS = 16 V maximum On-Resistance (RON) 12.5 Ω typ VS = 0 V to +4.5 V, IS = −10 mA; see Figure 22 14.7 17 Ω max VDD = 4.5 V, VSS = 0 V, On-Resistance Match Between Channels (∆RON) 0.15 Ω typ VS = 0 V to +4.5 V, IS = −10 mA 0.5 0.6 Ω max On-Resistance Flatness (RFLAT (ON)) 6.2 Ω typ VS = 0 V to +4.5 V, IS = −10 mA 8 8.9 Ω max LEAKAGE CURRENTS Normal Mode VDD = 5.5 V, VSS = 0 V Source Off Leakage, IS (Off ) ±0.8 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 23 ±3 ±80 nA max Drain Off Leakage, ID (Off ) ±0.8 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 23 ±3 ±80 nA max Channel On Leakage, ID (On), IS (On) ±2 nA typ VS = VD = 1 V or 4.5 V; see Figure 24 ±5 ±120 nA max Isolation Mode Source Off Leakage, IS (Off ) ±0.05 μA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V ±0.15 ±3 μA max VS = 1 V/16 V, VD = 16 V/1 V; see Figure 23 ±10 μA typ VDD = 5.5 V, VSS = 0 V ±28 ±38 μA max VS = 1 V/16 V, VD = 16 V/1 V ; Figure 23 Drain Off Leakage, ID (Off ) ±0.05 μA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V ±0.15 ±3 μA max VS = 1 V/16 V, VD = 16 V/1 V; see Figure 23 ±10 μA typ VDD = 5.5 V, VSS = 0 V ±28 ±38 μA max VS = 1 V/16 V, VD = 16 V/1 V ; see Figure 23 DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL ±0.015 μA typ VIN = VGND ±0.1 ±0.15 μA max Input Current, IINH ±13 μA typ VIN = VDD ±16 ±18 μA max Logic Pull-Down Resistance, RPD 400 kΩ typ Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 tON 116 ns typ RL = 300 Ω, CL = 35 pF 190 226 ns max VS = 3 V; see Figure 25 tOFF 87 ns typ RL = 300 Ω, CL = 35 pF 120 136 ns max VS = 3 V; see Figure 25 Break-Before-Make Time Delay, tD 70 ns typ RL = 50 Ω, CL = 35 pF (ADG4613 Only) 32 ns min VS1 = VS2 = 3 V; see Figure 26 Fault Response Time 240 ns typ VS = 2 V to 8 V, RL = 300 Ω, CL = 35 pF Fault Recovery Time 1.2 μs typ VS = 2 V to 8 V, RL = 300 Ω, CL = 35 pF Threshold Voltage, VT 1.8 V typ Charge Injection 75 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation −54 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 28 Rev. 0 | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS SPECIFICATIONS 5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, SX OR DX POWER SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION Normal Mode Isolation Mode Positive Fault Condition Negative Fault Condition; Negative Signal Handling APPLICATIONS INFORMATION Power Supply Sequencing OUTLINE DIMENSIONS ORDERING GUIDE
