Datasheet ADG5412, ADG5413 (Analog Devices)
Description | High Voltage Latch-Up Proof, Quad SPST Switches |
Pages / Page | 19 / 1 — High Voltage Latch-Up Proof,. Quad SPST Switches. Data Sheet. ADG5412/. … |
Revision | D |
File Format / Size | PDF / 469 Kb |
High Voltage Latch-Up Proof,. Quad SPST Switches. Data Sheet. ADG5412/. ADG5413. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Latch-up proof
High Voltage Latch-Up Proof, Quad SPST Switches Data Sheet ADG5412/ ADG5413 FEATURES FUNCTIONAL BLOCK DIAGRAMS Latch-up proof S1 S1 8 kV human body model (HBM) ESD rating IN1 IN1 Low on resistance (<10 Ω) D1 D1 ±9 V to ±22 V dual-supply operation S2 S2 9 V to 40 V single-supply operation IN2 IN2 48 V supply maximum ratings D2 D2 Fully specified at ±15 V, ±20 V, +12 V, and +36 V ADG5412 ADG5413 S3 S3 VSS to VDD analog signal range IN3 IN3 APPLICATIONS D3 D3 Relay replacement S4 S4 Automatic test equipment IN4 IN4 Data acquisition D4 D4
001
Instrumentation SWITCHES SHOWN FOR A LOGIC 1 INPUT.
09202-
Avionics
Figure 1.
Audio and video switching Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG5412/ADG5413 contain four independent single-pole/ 1. Trench isolation guards against latch-up. A dielectric trench single-throw (SPST) switches. The ADG5412 switches turn on separates the P and N channel transistors thereby preventing with Logic 1. The ADG5413 has two switches with digital control latch-up even under severe overvoltage conditions. logic similar to that of the ADG5412; however, the logic is inverted 2. Low RON. on the other two switches. Each switch conducts equally wel in 3. Dual-supply operation. For applications where the analog both directions when on, and each switch has an input signal signal is bipolar, the ADG5412/ADG5413 can be operated range that extends to the supplies. In the off condition, signal from dual supplies up to ±22 V. levels up to the supplies are blocked. 4. Single-supply operation. For applications where the analog The ADG5412 and ADG5413 do not have a V signal is unipolar, the ADG5412/ADG5413 can be operated L pin. The digital inputs are compatible with 3 V logic inputs over the full operating from a single rail power supply up to 40 V. supply range. 5. 3 V logic compatible digital inputs: VINH = 2.0 V, VINL = 0.8 V. 6. No VL logic power supply required. The on-resistance profile is very flat over the full analog input range, which ensures good linearity and low distortion when switching audio signals. High switching speed also makes the devices suitable for video signal switching. The ADG5413 exhibits break-before-make switching action for use in multiplexer applications.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2010–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
