Datasheet ADG5412W (Analog Devices) - 6
DescriptionHigh Voltage Latch-Up Proof, Quad SPST Switches
Pages / Page20 / 6 — ADG5412W. Data Sheet. 36 V SINGLE SUPPLY. Table 4. Typ. Parameter. Min. …
File Format / SizePDF / 397 Kb
ADG5412W. Data Sheet. 36 V SINGLE SUPPLY. Table 4. Typ. Parameter. Min. Max. Unit. Test Conditions/Comments
ADG5412W Data Sheet 36 V SINGLE SUPPLY Table 4 Typ Parameter Min Max Unit Test Conditions/Comments
link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 6
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, TA = –40°C to +125°C, unless otherwise noted.
Table 4. Typ Parameter Min
(TA = 25°C)
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 10.6 17 Ω VDD = 32.4 V, VSS = 0 V , VS = 0 V to 30 V, IS = −10 mA; see Figure 24 On-Resistance Match Between Channels, 0.35 1.1 Ω VS = 0 V to 30 V, IS = −10 mA ∆RON On-Resistance Flatness, RFLAT(ON) 2.7 4.5 Ω VS = 0 V to 30 V, IS = −10 mA LEAKAGE CURRENTS VDD = 39.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.05 ±10 nA VS = 1 V/30 V, VD = 30 V/1 V; see Figure 27 Drain Off Leakage, ID (Off) ±0.05 ±10 nA VS = 1 V/30 V, VD = 30 V/1 V; see Figure 27 Channel On Leakage, ID (On), IS (On) ±0.1 ±20 nA VS = VD = 1 V/30 V; see Figure 23 DIGITAL INPUTS Input High Voltage, VINH 2.0 V Input Low Voltage, VINL 0.8 V Input Current, IINL or IINH 0.002 ±0.1 µA VIN = VGND or VDD Digital Input Capacitance, CIN 2.5 pF DYNAMIC CHARACTERISTICS1 tON 180 248 ns VS = 18 V; see Figure 30, RL = 300 Ω, CL = 35 pF tOFF 130 174 ns VS = 18 V; see Figure 30, RL = 300 Ω, CL = 35 pF Charge Injection, QINJ 280 pC VS = 18 V, RS = 0 Ω, CL = 1 nF; see Figure 31 Off Isolation −78 dB RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Channel-to-Channel Crosstalk −70 dB RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 25 Total Harmonic Distortion + Noise 0.03 % RL = 1 kΩ, 18 V p-p, f = 20 Hz to 20 kHz; see Figure 28 −3 dB Bandwidth 174 MHz RL = 50 Ω, CL = 5 pF; see Figure 29 Insertion Loss −0.8 dB RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 CS (Off) 18 pF VS = 18 V, f = 1 MHz CD (Off) 18 pF VS = 18 V, f = 1 MHz CD (On), CS (On) 58 pF VS = 18 V, f = 1 MHz POWER REQUIREMENTS VDD = 39.6 V IDD 80 µA Digital inputs = 0 V or VDD 100 130 µA VDD 9 40 V GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 6 of 20 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Trench Isolation Outline Dimensions Ordering Guide Automotive Products
