Datasheet ADG5436 (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, Dual SPDT Switches
Pages / Page19 / 5 — Data Sheet. ADG5436. Parameter. 25°C −40°C to +85°C −40°C to +125°C Unit. …
RevisionC
File Format / SizePDF / 498 Kb
Data Sheet. ADG5436. Parameter. 25°C −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments. 12 V SINGLE SUPPLY
Data Sheet ADG5436 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 6
Insertion Loss −0.6 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 CS (Off) 18 pF typ VS = 0 V, f = 1 MHz CD (Off) 63 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 82 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 µA typ Digital inputs = 0 V or VDD 70 110 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 19 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 25 22 27 31 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match 0.4 Ω typ VS = 0 V to 10 V, IS = −10 mA Between Channels, ∆RON 0.8 1 1.2 Ω max On-Resistance Flatness, RFLAT (ON) 4.4 Ω typ VS = 0 V to 10 V, IS = −10 mA 5.5 6.5 7.5 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.25 ±0.75 ±6 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.4 ±2 ±12 nA max Channel On Leakage, ID (On), IS (On) ±0.1 nA typ VS = VD = 1 V/10 V; see Figure 24 ±0.4 ±2 ±12 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 250 ns typ RL = 300 Ω, CL = 35 pF 346 437 501 ns max VS = 8 V; see Figure 31 tON 250 ns typ RL = 300 Ω, CL = 35 pF 358 445 512 ns max VS = 8 V; see Figure 33 tOFF 135 ns typ RL = 300 Ω, CL = 35 pF 178 212 237 ns max VS = 8 V; see Figure 33 Break-Before-Make Time Delay, tD 125 ns typ RL = 300 Ω, CL = 35 pF 50 ns min VS1 = VS2 = 8 V; see Figure 32 Charge Injection, QINJ 80 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 34 Rev. C | Page 5 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE FOR SWITCHES TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
