Datasheet ADG1611, ADG1612, ADG1613 (Analog Devices) - 3
Description1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Quad SPST Switches
Pages / Page16 / 3 — Data Sheet. ADG1611/ADG1612/ADG1613. SPECIFICATIONS ±5 V DUAL SUPPLY. …
RevisionC
File Format / SizePDF / 489 Kb
Data Sheet. ADG1611/ADG1612/ADG1613. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to −40°C to. Parameter. 25°C. +85°C. +125°C. Unit
Data Sheet ADG1611/ADG1612/ADG1613 SPECIFICATIONS ±5 V DUAL SUPPLY Table 1 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 14 link to page 13
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 1 Ω typ VS = ±4.5 V, IS = −10 mA; see Figure 24 1.2 1.4 1.6 Ω max VDD = ±4.5 V, VSS = ±4.5 V On Resistance Match Between Channels (∆RON) 0.04 Ω typ VS = ±4.5 V, IS = −10 mA 0.08 0.09 0.1 Ω max On Resistance Flatness (RFLAT(ON)) 0.2 Ω typ VS = ±4.5 V, IS = −10 mA 0.25 0.29 0.34 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 25 ±0.3 ±1 ±6 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 25 ±0.3 ±1 ±6 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = ±4.5 V; see Figure 26 ±0.4 ±1.5 ±10 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH +0.005 ±0.1 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 tON 165 ns typ RL = 300 Ω, CL = 35 pF 212 253 285 ns max VS = 2.5 V; see Figure 31 tOFF 105 ns typ RL = 300 Ω, CL = 35 pF 137 150 159 ns max VS = 2.5 V; see Figure 31 Break-Before-Make Time Delay, tD (ADG1613 Only) 25 ns typ RL = 300 Ω, CL = 35 pF 20 ns min VS1 = VS2 = 2.5 V; see Figure 32 Charge Injection 140 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Channel-to-Channel Crosstalk 110 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Total Harmonic Distortion + Noise (THD + N) 0.007 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 30 −3 dB Bandwidth 42 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 29 CS (Off) 63 pF typ VS = 0 V, f = 1 MHz CD (Off) 63 pF typ VS = 0 V, f = 1 MHz CD, CS (On) 154 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +5.5 V, VSS = −5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD/VSS ±3.3/±8 V min/max 1 Guaranteed by design, not subject to production test. Rev. C | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
