Datasheet ADG1406, ADG1407 (Analog Devices) - 6
Description9.5 Ω RON, 16-Channel, Differential 8-Channel, ±15 V/+12 V/±5 V iCMOS Multiplexers
Pages / Page20 / 6 — ADG1406/ADG1407. Data Sheet. ±5 V DUAL SUPPLY. Table 4. −40°C to. …
RevisionC
File Format / SizePDF / 511 Kb
ADG1406/ADG1407. Data Sheet. ±5 V DUAL SUPPLY. Table 4. −40°C to. Parameter +25°C. +85°C. +125°C1 Unit. Test. Conditions/Comments
ADG1406/ADG1407 Data Sheet ±5 V DUAL SUPPLY Table 4 −40°C to Parameter +25°C +85°C +125°C1 Unit Test Conditions/Comments
link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 7 link to page 7
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 4. −40°C to −40°C to Parameter +25°C +85°C +125°C1 Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance (RON) 21 Ω typ VDD = +4.5 V, VSS = −4.5 V, VS = ±4.5 V, IS = −10 mA; see Figure 27 25 29 32 Ω max On-Resistance Match Between 0.6 Ω typ VDD = +4.5 V, VSS = −4.5 V, VS = ±4.5V, Channels (ΔRON) IS = −10 mA 1.3 1.7 1.9 Ω max On-Resistance Flatness (RFLAT(ON)) 5.2 Ω typ VDD = +4.5 V, VSS = −4.5 V, VS = ±4.5 V, IS = −10 mA 6.4 7.3 7.6 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off ) ±0.01 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 28 ±0.25 ±1 ±4 nA max Drain Off Leakage, ID (Off ) ±0.01 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 28 ±0.5 ±3 ±20 nA max Channel On Leakage, ID, IS (On) ±0.01 nA typ VS = VD = ±4.5 V; see Figure 29 ±0.5 ±3 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current ±0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 3.5 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 260 ns typ RL = 100 Ω, CL = 35 pF 435 510 565 ns max VS = 5 V; see Figure 30 Break-Before-Make Time Delay, tBBM 90 ns typ RL = 100 Ω, CL = 35 pF 30 ns min VS1 = VS2 = 5 V; see Figure 31 tON (EN) 230 ns typ RL = 100 Ω, CL = 35 pF 335 400 445 ns max VS = 5 V; see Figure 32 tOFF (EN) 205 ns typ RL = 100 Ω, CL = 35 pF 290 340 370 ns max VS = 5 V; see Figure 32 Charge Injection 10 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation –73 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 34 Channel-to-Channel Crosstalk –70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 35 Total Harmonic Distortion, THD + N 0.18 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 37 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 36 ADG1406 40 MHz typ ADG1407 80 MHz typ Insertion Loss 1.15 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 36 CS (Off ) 10 pF typ f = 1 MHz CD (Off ) f = 1 MHz ADG1406 123 pF typ ADG1407 62 pF typ CD, CS (On) f = 1 MHz ADG1406 148 pF typ ADG1407 88 pF typ Rev. C | Page 6 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
