Datasheet ADG1206, ADG1207 (Analog Devices) - 3
DescriptionLow Capacitance, 16-and 8-Channel, ±15 V/+12 V iCMOS Multiplexers
Pages / Page20 / 3 — Data Sheet. ADG1206/ADG1207. SPECIFICATIONS DUAL SUPPLY. Table 1. −40°C …
RevisionC
File Format / SizePDF / 386 Kb
Data Sheet. ADG1206/ADG1207. SPECIFICATIONS DUAL SUPPLY. Table 1. −40°C to. Parameter +25°C. +85°C. +125°C. Unit
Data Sheet ADG1206/ADG1207 SPECIFICATIONS DUAL SUPPLY Table 1 −40°C to Parameter +25°C +85°C +125°C Unit
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 4 link to page 4
VDD = +15 V ± 10%, VSS = –15 V ± 10%, GND = 0 V, unless otherwise noted.1
Table 1. −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance, RON 120 Ω typ VS = ±10 V, IS = −1 mA; see Figure 28 200 240 270 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match Between 3.5 Ω typ VS = ±10 V, IS = −1 mA Channels, ∆RON 6 10 12 Ω max On-Resistance Flatness, RFLAT (On) 20 Ω typ VS = −5 V, 0 V, +5 V; IS = −1 mA 64 76 83 Ω max LEAKAGE CURRENTS Source Off Leakage, IS (Off ) ±0.03 nA typ VD = ±10 V, VS = ∓10 V; see Figure 29 ±0.2 ±0.6 ±1 nA max Drain Off Leakage, ID (Off ) ±0.05 nA typ VS = 1 V, 10 V; VD = 10 V, 1 V; see Figure 29 ±0.2 ±0.6 ±2 nA max Channel On Leakage, ID, IS (On) ±0.08 nA typ VS = VD = ±10 V; see Figure 30 ±0.2 ±0.6 ±2 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.005 μA typ VIN = VINL or VINH ±0.1 μA max Digital Input Capacitance, CIN 2 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 80 ns typ RL = 300 Ω, CL = 35 pF 130 165 185 ns max VS = 10 V; see Figure 31 tON (EN) 75 ns typ RL = 300 Ω, CL = 35 pF 95 105 115 ns max VS = 10 V; see Figure 33 tOFF (EN) 85 ns typ RL = 300 Ω, CL = 35 pF 100 125 140 ns max VS = 10 V; see Figure 33 Break-Before-Make Time Delay, tBBM 20 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 10 V; see Figure 32 Charge Injection 0.5 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 34 Off Isolation −85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 35 Channel-to-Channel Crosstalk −85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 37 Total Harmonic Distortion Plus Noise 0.15 % typ RL = 10 kΩ, 5 V rms, f = 20 Hz to 20 kHz; see Figure 38 −3 dB Bandwidth, ADG1206 280 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 36 −3 dB Bandwidth, ADG1207 490 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 36 CS (Off ) 1.5 pF typ f = 1 MHz, VS = 0 V 2 pF max f = 1 MHz, VS = 0 V CD (Off ), ADG1206 11 pF typ f = 1 MHz, VS = 0 V 12 pF max f = 1 MHz, VS = 0 V CD (Off ), ADG1207 7 pF typ f = 1 MHz, VS = 0 V 9 pF max f = 1 MHz, VS = 0 V Rev. C | Page 3 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
