Datasheet ADG1308, ADG1309 (Analog Devices) - 5
Description4-and 8-Channel ±15 V/+12 V Multiplexers
Pages / Page16 / 5 — ADG1308/ADG1309. SINGLE SUPPLY. Table 2. Parameter. +25ºC. −40ºC to …
RevisionA
File Format / SizePDF / 364 Kb
ADG1308/ADG1309. SINGLE SUPPLY. Table 2. Parameter. +25ºC. −40ºC to +105ºC Unit. Test Conditions/Comments
ADG1308/ADG1309 SINGLE SUPPLY Table 2 Parameter +25ºC −40ºC to +105ºC Unit Test Conditions/Comments
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 5 link to page 5
VDD = 12 V, V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.1
Table 2. Parameter +25ºC −40ºC to +105ºC Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V On Resistance, RON 325 Ω typ VS = 0 V to 10 V, IS = −1 mA; see Figure 13 500 660 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between Channels, ∆RON 10 Ω typ VS = 0 V to 10 V, IS = −1 mA 20 Ω max On Resistance Flatness, RFLAT (On) 65 Ω typ VS = 3 V, 6 V, 9 V, IS = −1 mA LEAKAGE CURRENTS VDD = 13.2 V Source Off Leakage, IS (Off ) ±1 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 14 ±50 nA max Drain Off Leakage, ID (Off ) ±1 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 14 ±50 nA max Channel On Leakage, ID, IS (On) ±1 nA typ VS = VD = 1 V or 10 V; see Figure 15 ±50 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.001 ±0.1 μA max VIN = VINL or VINH Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 100 ns typ RL = 300 Ω, CL = 35 pF 170 240 VS = 8 V; see Figure 16 tON (EN) 90 ns typ RL = 300 Ω, CL = 35 pF 110 170 VS = 8 V; see Figure 18 tOFF (EN) 105 ns typ RL = 300 Ω, CL = 35 pF 130 180 VS = 8 V; see Figure 18 Break-Before-Make Time Delay, tBBM 45 ns typ RL = 300 Ω, CL = 35 pF 20 ns min VS1 = VS2 = 8 V; see Figure 17 Charge Injection 2 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 19 Off Isolation 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 20 Channel-to-Channel Crosstalk 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 21 −3 dB Bandwidth 500 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 22 CS (Off ) 5 pF typ f = 1 MHz, VS = 6 V CD (Off ) ADG1308 10 pF typ f = 1 MHz, VS = 6 V ADG1309 15 pF typ f = 1 MHz, VS = 6 V CD, CS (On) ADG1308 20 pF typ f = 1 MHz, VS = 6 V ADG1309 15 pF typ f = 1 MHz, VS = 6 V POWER REQUIREMENTS VDD = 13.2 V IDD 0.002 μA typ Digital inputs = 0 V or VDD 1.0 μA max IDD 220 μA typ Digital inputs = 5 380 μA max VDD 5/16.5 V min/V max VSS = 0 V, GND = 0 V 1 Temperature range for the B version is –40°C to +105°C. 2 Guaranteed by design; not subject to production test. Rev. A | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS ADG1308 TRUTH TABLE ADG1309 TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
