Datasheet DB201, DB202. DB203, DB204, DB205, DB206, DB207 (Rectron Semiconductor)
ManufacturerRectron Semiconductor
DescriptionSingle-Phase Glass Passivated Silicon Bridge Rectifier
Pages / Page5 / 1 — DB201. THRU. DB207. SINGLE-PHASE GLASS PASSIVATED. SILICON BRIDGE …
File Format / SizePDF / 82 Kb
DB201. THRU. DB207. SINGLE-PHASE GLASS PASSIVATED. SILICON BRIDGE RECTIFIER. VOLTAGE RANGE 50 to 1000 Volts CURRENT 2.0 Amperes
Datasheet DB201, DB202 DB203, DB204, DB205, DB206, DB207 Rectron Semiconductor
DB201 THRU DB207 SINGLE-PHASE GLASS PASSIVATED SILICON BRIDGE RECTIFIER VOLTAGE RANGE 50 to 1000 Volts CURRENT 2.0 Amperes FEATURES
* Good for automation insertion * Surge overload rating - 60 amperes peak * Ideal for printed circuit board * Reliable low cost construction utilizing molded * Glass passivated device
DB-1
* Polarity symbols molded on body * Mounting position: Any
MECHANICAL DATA
.255 (6.5) * Epoxy: Device has UL flammability classification 94V-O .245 (6.2) .350 (8.9) .300 (7.6) .335 (8.5) .307 (7.8) .118 (3.0) .093 (2.35)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
.193 (4.9) .020 Ratings at 25 oC ambient temperature unless otherwise specified. .155 (3.9) (0.5) resistive or inductive load. .060 .205 (5.2) (1.5) .195 (5.0) Dimensions in inches and (millimeters)
MAXIMUM RATINGS
(At TA = 25oC unless otherwise noted) RATINGS SYMBOL DB201 DB202 DB203 DB204 DB205 DB206 DB207 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS Bridge Input Voltage VRMS 35 70 140 280 420 560 700 Volts Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 Volts Maximum Average Forward Output Current at TA = 40oC IO 2.0 Amps Peak Forward Surge Current 8.3 ms single half sine-wave IFSM 60 Amps superimposed on rated load (JEDEC method) Typical Current Squared Time I2T 14.9 A2S R Q J A 40 Typical Thermal Resistance (Note 2) 0 R Q J L 15 C/ W Operating and Storage Temperature Range TJ,TSTG -55 to + 150 0 C
(At TA = 25oC unless otherwise noted) CHARACTERISTICS SYMBOL DB201 DB202 DB203 DB204 DB205 DB206 DB207 UNITS Maximum Forward Voltage Drop per Bridge VF 1.1 Volts Element at 2.0A DC Maximum Reverse Current at Rated @T uAmps A = 25oC 5.0 IR DC Blocking Voltage per element @TA = 125oC 0.5 mAmps Note: 1.”Ro HS c ompliant” 2021-07 2. Thermal Resistance: Mounted on PCB. REV:A 3. Available in Halogen-free epoxy by adding suffix -HF after the part nbr.
