Datasheet ADG1334 (Analog Devices)
DescriptionQuad SPDT ±15 V/+12 V Switches
Pages / Page12 / 1 — Quad SPDT. ±15 V/+12 V Switches. ADG1334. FEATURES. FUNCTIONAL BLOCK …
File Format / SizePDF / 319 Kb
Quad SPDT. ±15 V/+12 V Switches. ADG1334. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 33 V supply range 130 Ω on resistance. S1A. S4A
Datasheet ADG1334 Analog Devices
Quad SPDT ±15 V/+12 V Switches ADG1334 FEATURES FUNCTIONAL BLOCK DIAGRAM 33 V supply range 130 Ω on resistance S1A S4A Fully specified at ±15 V/+12 V D1 D2 S1B S4B 3 V logic compatible inputs Rail-to-rail operation IN1 IN4 Break-before-make switching action ADG1334 20-lead SSOP IN2 IN3 APPLICATIONS S2B S3B D2 D3 Audio and video routing S2A S3A Battery-powered systems
01 -0
Signal routing
744
SWITCHES SHOWN FOR A LOGIC 1 INPUT
05 Figure 1.
GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG1334 is a monolithic CMOS device comprising 1. 3 V logic compatible digital input VIH = 2.0 V, VIL = 0.8 V. four independently selectable SPDT switches designed on a 2. No VL logic power supply required. CMOS process. 3. Low power consumption. When the switches are on, each switch conducts equally well 4. 20-lead SSOP. in both directions and has an input signal range that extends to the power supplies. In the off condition, signal levels up to the supplies are blocked. All switches exhibit break-before-make switching action for use in multiplexer applications. Inherent in the design is the low charge injection for minimum transients when switching the digital inputs. Fast switching speed coupled with high signal bandwidth makes the part suitable for video signal switching. CMOS construction ensures ultra ow power dissipation, making the part ideally suited for portable and battery-powered instruments.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
