Datasheet ADG1311, ADG1312, ADG1313 (Analog Devices) - 6
Description±15 V/12 V Quad SPST Switches
Pages / Page12 / 6 — ADG1311/ADG1312/ADG1313. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
RevisionA
File Format / SizePDF / 280 Kb
ADG1311/ADG1312/ADG1313. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. 16 IN2. ADG1311/. ADG1312/. VDD. ADG1313. GND. TOP VIEW. IN4. IN3
ADG1311/ADG1312/ADG1313 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN1 16 IN2 ADG1311/ ADG1312/ VDD ADG1313 GND TOP VIEW IN4 IN3
ADG1311/ADG1312/ADG1313 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN1 1 16 IN2 D1 2 15 D2 S1 3 14 S2 ADG1311/ V 4 SS ADG1312/ 13 VDD ADG1313 GND 5 12 NC TOP VIEW S4 6 11 S3 D4 7 10 D3 8 9 IN4 IN3 NC = NO CONNECT
05676-002 Figure 2. SOIC/TSSOP Pin Configuration
Table 6. Pin Function Descriptions Pin No. Mnemonic Description
1 IN1 Logic Control Input. 2 D1 Drain Terminal. Can be an input or output. 3 S1 Source Terminal. Can be an input or output. 4 VSS Most Negative Power Supply Potential. 5 GND Ground (0 V) Reference. 6 S4 Source Terminal. Can be an input or output. 7 D4 Drain Terminal. Can be an input or output. 8 IN4 Logic Control Input. 9 IN3 Logic Control Input. 10 D3 Drain Terminal. Can be an input or output. 11 S3 Source Terminal. Can be an input or output. 12 NC No Connection. 13 VDD Most Positive Power Supply Potential. 14 S2 Source Terminal. Can be an input or output. 15 D2 Drain Terminal. Can be an input or output. 16 IN2 Logic Control Input. Rev. A | Page 6 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
