Datasheet ADG1311, ADG1312, ADG1313 (Analog Devices) - 8
Description±15 V/12 V Quad SPST Switches
Pages / Page12 / 8 — ADG1311/ADG1312/ADG1313. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 600. …
File Format / SizePDF / 280 Kb
ADG1311/ADG1312/ADG1313. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 600. TA = 25. VDD = 12V. 180. VSS = 0V. 500. 160. TA = +85. 140. DD = +15V
ADG1311/ADG1312/ADG1313 TYPICAL PERFORMANCE CHARACTERISTICS 200 600 TA = 25 VDD = 12V 180 VSS = 0V 500 160 TA = +85 140 DD = +15V
C VDD = 12V 180 VSS = 0V 500 160 TA = +85
C ) V 140 DD = +15V )
Ω Ω
V ( SS = –15V ( 400 120 TANCE 100 TANCE 300 IS IS S S 80 200 ON RE 60 ON RE TA = –40
C TA = +25
C 40 100 20 0
05676-008
0
05676-007
–15 –12 –9 –6 –3 0 3 6 9 12 15 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 3. On Resistance as a Function of VD (VS) for Dual Supply Figure 6. On Resistance as a Function of VD (VS) for Different Temperatures, Single Supply
450 200 TA = 25
C 400 180 12V SS TON 350 160 )
Ω
140 ( 300 V 120 15V DS T DD = 12V ON 250 VSS = 0V TANCE 100 IS S 200 TIME (ns) 80 150 12V SS T ON RE OFF 60 100 40 15V DS TOFF 50 20 0
05676-005
0
05676-016
0 2 4 6 8 10 12 –40 –20 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (
C)
Figure 4. On Resistance as a Function of VD (VS) for Single Supply Figure 7. TON/TOFF Times vs. Temperature
250 0 VDD = +15V V V DD = +15V SS = –15V –10 VSS = –15V TA = 25
C 200 –20 ) –30
Ω
( –40 150 T –50 TANCE A = +85
C IS S OLATION (dB) –60 100 TA = +25
C –70 ON RE TA = –40
C OFF IS –80 50 –90 –100 0
05676-006
–110
05676-017
–15 –10 –5 0 5 10 15 10k 100k 1M 10M 100M 1G SOURCE OR DRAIN VOLTAGE (V) FREQUENCY (Hz)
Figure 5. On Resistance as a Function of VD (VS) for Different Figure 8. Off Isolation vs. Frequency Temperatures, Dual Supply Rev. A | Page 8 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
