Datasheet ADG633 (Analog Devices) - 4
DescriptionCMOS, ±5 V/+5 V/+3 V, Triple SPDT Switch
Pages / Page16 / 4 — ADG633. Data Sheet. SINGLE-SUPPLY OPERATION. Table 2. Parameter. +25°C. …
RevisionB
File Format / SizePDF / 388 Kb
ADG633. Data Sheet. SINGLE-SUPPLY OPERATION. Table 2. Parameter. +25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
ADG633 Data Sheet SINGLE-SUPPLY OPERATION Table 2 Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13
VDD = 5 V, VSS = 0 V, GND = 0 V, TA = −40°C to +125°C, unless otherwise noted.
Table 2. Parameter +25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V VDD = 4.5 V, VSS = 0 V On Resistance, RON 85 Ω typ VS = 0 V to 4.5 V, IS = 1 mA; see Figure 20 150 160 200 Ω max VS = 0 V to 4.5 V, IS = 1 mA; see Figure 20 On-Resistance Match 4.5 Ω typ VS = +3.5 V, IS = 1 mA Between Channels, ΔRON 8 9 10 Ω max VS = +3.5 V, IS = 1 mA On-Resistance Flatness, RFLAT(ON) 13 14 16 Ω typ VDD = 5 V, VSS = 0 V, VS = 1.5 V to 4 V, IS = 1 mA LEAKAGE CURRENTS VDD = 5.5 V Source Off Leakage, IS(OFF) ±0.005 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 21 ±0.2 ±5 nA max VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 21 Drain Off Leakage, ID(OFF) ±0.005 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 22 ±0.2 ±5 nA max VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 22 Channel On Leakage, ID(ON), IS(ON) ±0.005 nA typ VS = VD = 1 V or 4.5 V; see Figure 23 ±0.2 ±5 nA max VS = VD = 1 V or 4.5 V; see Figure 23 DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VINL or VINH ±1 μA max VIN = VINL or VINH Digital Input Capacitance, CIN 2 pF typ DYNAMIC CHARACTERISTICS1 tTRANSITION 100 ns typ RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 24 150 190 220 ns max RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 24 tON (EN) 100 ns typ RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 26 150 190 220 ns max RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 26 tOFF (EN) 25 ns typ RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 26 35 45 50 ns max RL = 300 Ω, CL = 35 pF, VS = 3 V; see Figure 26 Break-Before-Make Time Delay, tBBM 90 ns typ RL = 300 Ω, CL = 35 pF, VS1 = VS2 = 3 V; see Figure 25 10 ns min RL = 300 Ω, CL = 35 pF, VS1 = VS2 = 3 V; see Figure 25 Charge Injection 0.5 pC typ VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 27 1 pC max VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Channel-to-Channel Crosstalk −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 −3 dB Bandwidth 520 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 29 CS(OFF) 5 pF typ f = 1 MHz CD(OFF) 8 pF typ f = 1 MHz CD(ON), CS(ON) 12 pF typ f = 1 MHz POWER REQUIREMENTS2 VDD = 5.5 V IDD 0.01 μA typ Digital inputs = 0 V or 5.5 V 1 μA max Digital inputs = 0 V or 5.5 V 1 Guaranteed by design; not subject to production test. 2 The device is fully specified at a ±5 V dual supply and at 5 V and 3.3 V single supplies. It is possible to operate the ADG633 with unbalanced supplies or at other voltage supplies ( ±2 V to ±6 V, and 2 V to 12 V); however, the switch characteristics change. These changes include, but are not limited to: analog signal range, on resistance, leakage, VINL, VINH, and switching times. The optimal power-up sequence for the device is: ground, VDD, VSS, and then the digital inputs, before applying the analog input signal. Rev. B | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION SINGLE-SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
