Datasheet ADG633 (Analog Devices) - 6
DescriptionCMOS, ±5 V/+5 V/+3 V, Triple SPDT Switch
Pages / Page16 / 6 — ADG633. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. …
File Format / SizePDF / 388 Kb
ADG633. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. ESD CAUTION
ADG633 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
T A = 25°C, unless otherwise noted.
Table 4.
Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these V to V 1 13 V DD SS or any other conditions above those indicated in the operational V to GND −0.3 V to +13 V DD section of this specification is not implied. Operation beyond V to GND +0.3 V to −6.5 V SS the maximum operating conditions for extended periods may Analog Inputs2 V − 0.3 V to V + 0.3 V SS DD affect product reliability. Digital Inputs2 GND − 0.3 V to V + 0.3 V or DD 10 mA, whichever occurs first Only one absolute maximum rating can be applied at any one time. Peak Current, S or D 40 mA (pulsed at 1 ms, 10% duty cycle maximum)
ESD CAUTION
Continuous Current, S or D 20 mA Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θ Thermal Impedance JA 16-Lead TSSOP 150.4°C/W 16-Lead LFCSP, 4-Layer Board 70°C/W Lead Soldering Lead Temperature, Soldering 300°C (10 sec) IR Reflow, Peak Temperature 220°C (<20 sec) (Pb-Free) Soldering Reflow, Peak Temperature 260(+0/−5)°C Time at Peak Temperature 20 sec to 40 sec ESD 4 kV 1 The device is ful y specified at a ±5 V dual supply and at 5 V and 3.3 V single supplies. It is possible to operate the ADG633 with unbalanced supplies or at other voltage supplies ( ±2 V to ±6 V, and 2 V to 12 V); however, the switch characteristics change. These changes include, but are not limited to: analog signal range, on resistance, leakage, VINL, VINH, and switching times. The optimal power-up sequence for the device is: ground, VDD, VSS, and then the digital inputs, before applying the analog input signal. 2 Overvoltages at Ax, EN, S, or D are clamped by internal diodes. Limit current to the maximum ratings given. Rev. B | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION SINGLE-SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
