Datasheet ADG633 (Analog Devices) - 9
Description | CMOS, ±5 V/+5 V/+3 V, Triple SPDT Switch |
Pages / Page | 16 / 9 — Data Sheet. ADG633. 1.5. 300. VDD = +5V. VDD = +3V. VSS = 0V. VD = ±4V. … |
Revision | B |
File Format / Size | PDF / 388 Kb |
Data Sheet. ADG633. 1.5. 300. VDD = +5V. VDD = +3V. VSS = 0V. VD = ±4V. VD = ±2.4V. 1.0. 250. S = 1V. VS = 1V. DD = 3V. n (. 0.5. 200. IS(OFF), ID(OFF)
Data Sheet ADG633 1.5 300 VDD = +5V VDD = +3V VSS = 0V VSS = 0V VSS = 0V VD = ±4V VD = ±2.4V 1.0 V 250 S = 1V VS = 1V V A) DD = 3V n ( 0.5 200 NT IS(OFF), ID(OFF) ) s 0 150 CURRE E IME (n T t V ON DD = 5V –0.5 100 AKAG E IS(ON), ID(ON) L –1.0 50 t VDD = 3V OFF –1.5 0 0 20 40 60 80 100 120
010
–40 –20 0 20 40 60 80 100 120
013
TEMPERATURE (°C) TEMPERATURE (°C)
03275- 03275- Figure 10. Leakage Current vs. Temperature, Single Supply Figure 13. tON/tOFF Times vs. Temperature, Single Supply
14 0 TA = 25°C VDD = +5V V 12 SS = –5V TA = 25°C 10 –2 8 B) d –4 C) N ( 6 p IO ( INJ 4 Q V NUAT DD = +3V E –6 V T SS = 0V 2 VDD = +5V AT VSS = –5V 0 –8 VDD = +5V –2 VSS = 0V –4 –10 –5 –4 –3 –2 –1 0 1 2 3 4 5
011
100k 1M 10M 100M
014
VS (V) FREQUENCY (Hz)
03275- 03275- Figure 11. Charge Injection vs. Source Voltage Figure 14. On Response vs. Frequency
100 0 VDD = +5V VDD = +5V 90 VSS = –5V VSS = –5V TA = 25°C –20 80 tON 70 ) dB –40 ( ) 60 s TION 50 –60 IME (n OLA T 40 –80 30 OFF IS tOFF 20 –100 10 0 –120 –40 –20 0 20 40 60 80 100 120
012
100k 1M 10M 100M
015
TEMPERATURE (°C) FREQUENCY (Hz)
03275- 03275- Figure 12. tON/tOFF Times vs. Temperature, Dual Supplies Figure 15. Off Isolation vs. Frequency Rev. B | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION SINGLE-SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
