Datasheet ADG658, ADG659 (Analog Devices) - 5
Description+3 V/+5 V/±5 V CMOS 4-and 8-Channel Analog Multiplexers
Pages / Page20 / 5 — Data Sheet. ADG658/ADG659. 5 V SINGLE SUPPLY. Table 2. B Version. Y …
RevisionD
File Format / SizePDF / 397 Kb
Data Sheet. ADG658/ADG659. 5 V SINGLE SUPPLY. Table 2. B Version. Y Version. −40°C. Parameter. +25°C. to +85°C. to +125°C. Unit
Data Sheet ADG658/ADG659 5 V SINGLE SUPPLY Table 2 B Version Y Version −40°C Parameter +25°C to +85°C to +125°C Unit
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 16 link to page 17 link to page 17 link to page 18 link to page 17 link to page 6
VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. B Version Y Version −40°C −40°C Parameter +25°C to +85°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V VDD = 4.5 V, VSS = 0 V On Resistance (RON) 85 Ω typ VS = 0 V to 4.5 V, IS = 1 mA; see Figure 21 150 160 200 Ω max On Resistance Match between 4.5 Ω typ VS = 3.5 V, IS = 1 mA Channels (∆RON) 8 9 10 Ω max On Resistance Flatness (RFLAT(ON)) 13 14 16 Ω typ VDD = 5 V, VSS = 0 V, VS = 1.5 V to 4 V, IS = 1 mA LEAKAGE CURRENTS VDD = 5.5 V Source OFF Leakage IS (OFF) ±0.005 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 22 ±0.2 ±5 nA max Drain OFF Leakage ID (OFF) ±0.005 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 23 ADG658 ±0.2 ±5 nA max ADG659 ±0.1 ±2.5 nA max Channel ON Leakage ID, IS (ON) ±0.005 nA typ VS = VD = 1 V or 4.5 V, see Figure 24 ADG658 ±0.2 ±5 nA max ADG659 ±0.1 ±2.5 nA max DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current IINL or IINH 0.005 µA typ VIN = VINL or VINH ±1 µA max CIN, Digital Input Capacitance 2 pF typ DYNAMIC CHARACTERISTICS1 tTRANSITION 120 ns typ RL = 300 Ω, CL = 35 pF 200 270 300 ns max VS = 3 V; see Figure 25 tON (EN) 120 ns typ RL = 300 Ω, CL = 35 pF 190 245 280 ns max VS = 3 V; see Figure 27 tOFF (EN) 35 ns typ RL = 300 Ω, CL = 35 pF 50 60 70 ns max VS = 3 V; see Figure 27 Break-Before-Make Time Delay, tBBM 100 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 3 V; see Figure 26 Charge Injection 0.5 pC typ VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 28 1 pC max Off Isolation −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Channel-to-Channel Crosstalk −90 dB typ RL = 50 Ω, CL = 5 pF; f = 1 MHz; see Figure 31 (ADG659) −3 dB Bandwidth ADG658 180 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 30 ADG659 330 MHz typ CS (OFF) 5 pF typ f = 1 MHz CD (OFF) ADG658 29 pF typ f = 1 MHz ADG659 15 pF typ f = 1 MHz Rev. D | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY 5 V SINGLE SUPPLY 2.7 V TO 3.6 V SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
