Datasheet ADG725, ADG731 (Analog Devices)
Description | 16-/32-Channel, Serially Controlled 4 1.8 V to 5.5 V, 2.5 V, Analog Multiplexers |
Pages / Page | 17 / 1 — 16-/32-Channel, Serially Controlled 4. 1.8 V to 5.5 V,. 2.5 V, Analog … |
Revision | B |
File Format / Size | PDF / 264 Kb |
16-/32-Channel, Serially Controlled 4. 1.8 V to 5.5 V,. 2.5 V, Analog Multiplexers. ADG725/. ADG731. FEATURES
a
16-/32-Channel, Serially Controlled 4 1.8 V to 5.5 V, 2.5 V, Analog Multiplexers ADG725/ ADG731 FEATURES FUNCTIONAL BLOCK DIAGRAM 3-Wire SPI Compatible Serial Interface 1.8 V to 5.5 V Single Supply ADG731 ADG725 2.5 V Dual-Supply Operation 4 On Resistance S1 S1A DA 0.5 On Resistance Flatness S16A 7 mm x 7 mm 48-Lead Chip Scale Package (LFCSP) or 48-Lead TQFP Package D Rail-to-Rail Operation S1B Power-On Reset DB 42 ns Switching Times S32 S16B Single 32-to-1 Channel Multiplexer Dual/Differential 16-to-1 Channel Multiplexer INPUT SHIFT INPUT SHIFT REGISTER REGISTER TTL/CMOS Compatible Inputs For Functionally Equivalent Devices with Parallel Interface, See ADG726/ADG732 SCLK DIN SYNC SCLK DIN SYNC APPLICATIONS Optical Applications Data Acquisition Systems Communication Systems Relay Replacement Audio and Video Switching Battery-Powered Systems Medical Instrumentation Automatic Test Equipment GENERAL DESCRIPTION
These parts can operate equally well as either multiplexers or The ADG731/ADG725 are monolithic, CMOS, 32-channel/ demultiplexers and have an input signal range that extends to the dual 16-channel analog multiplexers with a serially controlled supplies. In the OFF condition, signal levels up to the supplies 3-wire interface. The ADG731 switches one of 32 inputs are blocked. All channels exhibit break-before-make switching (S1–S32) to a common output, D. The ADG725 can be config- action, preventing momentary shorting when switching channels. ured as a dual mux switching one of 16 inputs to one output, or a The ADG731 and ADG725 are serially controlled 32-channel, differential mux switching one of 16 inputs to a differential output. and dual/differential 16-channel multiplexers, respectively. They These mulitplexers utilize a 3-wire serial interface that is com- are available in either a 48-lead LFCSP or TQFP package. patible with SPI®, QSPI™, MICROWIRE™, and some DSP interface standards. On power-up, the Internal Shift Register
PRODUCT HIGHLIGHTS
contains all zeros and all switches are in the OFF state. 1. 3-Wire Serial Interface. These multiplexers are designed on an enhanced submicron 2. 1.8 V to 5.5 V Single-Supply or ± 2.5 V Dual-Supply process that provides low power dissipation yet gives high switch- Operation. These parts are specified and guaranteed ing speed with very low on resistance and leakage currents. with 5 V ± 10%, 3 V ± 10% single-supply, They operate from a single supply of 1.8 V to 5.5 V or a and ± 2.5 V ± 10% dual-supply rails. ±2.5 V dual supply, making them ideally suited to a variety of 3. On Resistance of 4 W. applications. On resistance is in the region of a few ohms, is closely matched between switches, and is very flat over the full 4. Guaranteed Break-Before-Make Switching Action. signal range. 5. 7 mm ¥ 7 mm 48-Lead Chip Scale Package (LFCSP) or 48-Lead TQFP Package.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Specifications subject to change without notice. No license is granted by implication Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. or otherwise under any patent or patent rights of Analog Devices. Trademarks and Technical Support www.analog.com registered trademarks are the property of their respective owners.
