ADG601/ADG602Data SheetPIN CONFIGURATIONS AND FUNCTION DESCRIPTIONSPIN 1VDPIN 18 SDD1INDICATOR6 IN1INDICATORADG601/NC 2ADG601/7 GNDSADG6022ADG6025 DNC 36 INTOP VIEWTOP VIEW(Not to Scale)VDD 4 (Not to Scale) 5 VSS 3 02 00 V 0 9- SS34 GND 19- NC = NO CONNECT 26 261 0 0 Figure 2. 6-Lead SOT-23 (RJ-6) Figure 3. 8-Lead MSOP (RM-8) Table 5. Pin Function DescriptionsPin No.6-Lead SOT-238-Lead MSOPMnemonic Description 1 4 VDD Most Positive Power Supply Potential. 2 8 S Source Terminal. Can be an input or output. 3 5 VSS Most Negative Power Supply Potential. 4 7 GND Ground (0 V) Reference. 5 1 D Drain Terminal. Can be an input or output. 6 6 IN Logic Control Input. N/A1 2, 3 NC No Connect. 1 N/A is not applicable. 1142133 412511610789 1 02 9- TOP VIEW 61 (Not to Scale) 02 Figure 4. Die (820 μm × 2255 μm) Table 6. Die Pad Coordinates1Die PadCoordinatesDie Pad No.X (μm)Y (μm)Mnemonic Description 1 −265 +754 NC No Connect. 2 −265 +525 D Drain Terminal. Can be an input or output.2 3 −265 +241 D Drain Terminal. Can be an input or output.2 4 −265 +141 D Drain Terminal. Can be an input or output.2 5 −265 −191 NC No Connect. 6 −265 −409 NC No Connect. 7 −265 −549 NC No Connect. 8 −265 −787 VDD Most Positive Power Supply Potential. 9 +265 −767 VSS Most Negative Power Supply Potential. 10 +265 −429 IN Logic Control Input. 11 +265 −289 GND Ground (0 V) Reference. 12 +265 +189 S Source Terminal. Can be an input or output.3 13 +265 +521 S Source Terminal. Can be an input or output.3 14 +265 +661 NC Source Terminal. Can be an input or output. 1 Measured from the center of the die. 2 Bond the D pads together to a single point to preserve the on resistance and current handling capability. The common point acts as the drain pin of the switch. 3 Bond the S pads together to a single point to preserve the on resistance and current handling capability. The common point acts as the source pin of the switch. Rev. D | Page 6 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
