Datasheet ADG786, ADG788 (Analog Devices) - 5
Description2.5 , 1.8 V to 5.5 V, 2.5 V Triple/Quad SPDT Switches in Chip Scale Packages
Pages / Page11 / 5 — ADG786/ADG788. ABSOLUTE MAXIMUM RATINGS1. CAUTION. WARNING!. ESD …
RevisionC
File Format / SizePDF / 368 Kb
ADG786/ADG788. ABSOLUTE MAXIMUM RATINGS1. CAUTION. WARNING!. ESD SENSITIVE DEVICE. PIN CONFIGURATIONS. S2B. S1A. IN1. IN4. S4A
ADG786/ADG788 ABSOLUTE MAXIMUM RATINGS1 CAUTION WARNING! ESD SENSITIVE DEVICE PIN CONFIGURATIONS S2B S1A IN1 IN4 S4A
Storage Temperature Range . –65°C to +150°C (TA = 25°C unless otherwise noted) Junction Temperature . 150°C V 20 Lead CSP, θ DD to VSS . 7 V JA Thermal Impedance . 32°C/W V Lead Temperature, Soldering (10 sec) . 300°C DD to GND . –0.3 V to +7 V V IR Reflow, Peak Temperature . 220°C SS to GND . +0.3 V to –3.5 V Analog Inputs2 . VSS – 0.3 V to VDD + 0.3 V or NOTES 30 mA, Whichever Occurs First 1Stresses above those listed under Absolute Maximum Ratings may cause perma- Digital Inputs2 . –0.3 V to V nent damage to the device. This is a stress rating only; functional operation of the DD + 0.3 V or device at these or any other conditions above those listed in the operational 30 mA, Whichever Occurs First sections of this specification is not implied. Exposure to absolute maximum rating Peak Current, S or D . 100 mA conditions for extended periods may affect device reliability. Only one absolute (Pulsed at 1 ms, 10% Duty Cycle max) maximum rating may be applied at any one time. Continuous Current, S or D . 30 mA 2Overvoltages at A, EN, IN, S, or D will be clamped by internal diodes. Current Operating Temperature Range should be limited to the maximum ratings given. Industrial (A, B Versions) . –40°C to +85°C
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the ADG786/ADG788 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality.
ESD SENSITIVE DEVICE PIN CONFIGURATIONS DD S2B NC NC NC V S1A IN1 IN4 S4A D4 20 19 18 17 16 20 19 18 17 16 PIN 1 PIN 1 S2A IDENTIFIER 1 15 D2 D1 IDENTIFIER 1 15 S4B S3B 2 14 NC S1B 2 14 VDD ADG786 ADG788 D3 3 13 D1 V 3 13 S3B TOP VIEW SS TOP VIEW S3A (Not to Scale) 4 12 S1B GND (Not to Scale) 4 12 D3 EN 5 11 S1A S2B 5 11 S3A 6 7 8 9 10 6 7 8 9 10 SSV A2 A1 A0 D2 GND S2A IN2 IN3 NC NC = NO CONNECT EXPOSED PAD TIED TO SUBSTRATE, VSS
REV.$ –5–
