Datasheet ADG758, ADG759 (Analog Devices) - 8
Description | 3 Ω, 4-/8-Channel Multiplexers in Chip Scale Package |
Pages / Page | 12 / 8 — ADG758/ADG759. 0.12. 0.35. VDD = 3V. VSS = 0V. 0.30. SS = 0V. 0.08. TA = … |
Revision | B |
File Format / Size | PDF / 362 Kb |
ADG758/ADG759. 0.12. 0.35. VDD = 3V. VSS = 0V. 0.30. SS = 0V. 0.08. TA = 25. 0.25. 0.04. ID (ON), VS = VD. 0.20. 0.00. 0.15. CURRENT – nA. 0.10. –0.04
ADG758/ADG759 0.12 0.35 VDD = 3V VDD = 3V VSS = 0V V 0.30 SS = 0V 0.08 TA = 25 C 0.25 0.04 ID (ON), VS = VD 0.20 0.00 0.15 CURRENT – nA CURRENT – nA 0.10 –0.04 IS (OFF) ID (OFF) ID (OFF) 0.05 –0.08 0.00 ID (ON) IS (OFF) –0.12 –0.05 0 0.5 1.0 1.5 2.0 2.5 3.0 15 25 35 45 55 65 75 85 VS, (VD = VDD – VS) – V TEMPERATURE – C
TPC 7. Leakage Currents as a Function of VD (VS) TPC 10. Leakage Currents as a Function of Temperature
0.12 10m VDD = +2.5V TA = 25 C VSS = –2.5V 0.08 T 1m A = 25 C VDD = +2.5V 100 V 0.04 I SS = –2.5V D (ON), VS = VD 10 V 0.00 DD = +5V 1 CURRENT – nA CURRENT – A VDD = +3V –0.04 IS (OFF) 100n –0.08 ID (OFF) 10n –0.12 1n –3.0 –2.5 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 10 100 1k 10k 100k 1M 10M VS, (VD = VDD – VS) – V FREQUENCY – Hz
TPC 8. Leakage Currents as a Function of VD (VS) TPC 11. Supply Current vs. Input Switching Frequency
0.35 0 V V DD = 5V DD = 5V, VSS = 0V T V 0.30 A = 25 C DD = +2.5V, VSS = –2.5V –20 0.25 –40 0.20 0.15 –60 I CURRENT – nA 0.10 D (OFF) ATTENUATION – dB –80 0.05 ID (ON) –100 0.00 IS (OFF) –0.05 –120 15 25 35 45 55 65 75 85 30k 100k 1M 10M 100M TEMPERATURE – C FREQUENCY – Hz
TPC 9. Leakage Currents as a Function of Temperature TPC 12. OFF Isolation vs. Frequency –8– REV. B
