Datasheet ADG706, ADG707 (Analog Devices) - 7
DescriptionCMOS, +1.8 V to +5.5 V/ⴞ2.5 V, 2.5 ⍀ Low-Voltage, 8-/16-Channel Multiplexers
Pages / Page12 / 7 — Typical Performance Characteristics–ADG706/ADG707. TA = 25. DD = 5V. DD = …
File Format / SizePDF / 263 Kb
Typical Performance Characteristics–ADG706/ADG707. TA = 25. DD = 5V. DD = +2.5V. VSS = GND. SS = 0V. SS = –2.5V. VDD = 2.7V. VDD = 3.3V
Typical Performance Characteristics–ADG706/ADG707 TA = 25 DD = 5V DD = +2.5V VSS = GND SS = 0V SS = –2.5V VDD = 2.7V VDD = 3.3V
Typical Performance Characteristics–ADG706/ADG707 8 8 8 TA = 25
C V V DD = 5V DD = +2.5V 7 VSS = GND 7 V 7 V SS = 0V SS = –2.5V VDD = 2.7V 6 6 6
5 5 5 VDD = 3.3V 4 4 V +25
C 4 DD = 4.5V +25
C 3 3 +85
C 3 +85
C ON RESISTANCE – ON RESISTANCE – ON RESISTANCE – 2 2 2 VDD = 5.5V –40
C –40
C 1 1 1 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5
2.75
2.00
1.00 0 1.00 2.00 2.75 VD OR VS, DRAIN OR SOURCE VOLTAGE – V VD OR VS, DRAIN OR SOURCE VOLTAGE – V VD OR VS, DRAIN OR SOURCE VOLTAGE – V
TPC 1. ON Resistance as a Function TPC 2. ON Resistance as a Function TPC 3. ON Resistance as a Function of VD (VS) for Single Supply of VD (VS) for Different Temperatures, of VD (VS) for Different Temperatures, Single Supply Dual Supply
8 8 0.3 TA = 25
C VDD = 3V VDD = 5V 7 7 VSS = 0V VSS = 0V 0.2 T I A = 25
C D (OFF) 6
6
ID, IS (ON) V +85
C DD = +2.5V 5 5 V 0.1 SS = –2.5V 4 4 –40
C 0 3 3 CURRENT – nA ON RESISTANCE – ON RESISTANCE – IS (OFF) 2 2 +25
C
0.1 1 1 0 0
0.2
3 –2
1 0 1 2 3 0 0.5 1.0 1.5 2.0 2.5 3.0 0 1 2 3 4 5 VD OR VS, DRAIN OR SOURCE VOLTAGE – V VD OR VS , DRAIN OR SOURCE VOLTAGE – V VD (VD = VDD – VS) – V
TPC 4. ON Resistance as a Function TPC 5. ON Resistance as a Function TPC 6. Leakage Currents as a Function of VD (VS) for Dual Supply of VD (VS) for Different Temperatures, of VD (VS) Single Supply
0.3 0.3 VDD V V DD = 3V I DD = +2.5V D (OFF) VDD 0.2 V V SS = 0V SS = –2.5V 0.2 ID (OFF) T T S1 A3 A = 25
C A = 25
C 50
A2 S16 0.1 0.1 VS A1 ADG706* A0 0 0 D EN** VOUT I R CURRENT – nA –0.1 D, IS (ON) IS (OFF) CURRENT – nA V L –0.1 I GND SS I S (OFF) 50
D, IS (ON) VSS –0.2 –0.2 *SIMILAR CONNECTION FOR ADG707 **CONNECT TO 2.4V FOR BANDWIDTH MEASUREMENTS –0.3 OFF ISOLATION = 20LOG –0.3 10(VOUT /VS) 0 1 2 3 4 5 –2.75 –2.00 –1.00 0 1.00 2.00 2.75 INSERTION LOSS = 20LOG10 VOUT WITH SWITCH
V V D (VD = VDD – VS) – V VD (VD = VDD – VS) – V OUT WITHOUT SWITCH
TPC 7. Leakage Currents as a Function TPC 8. Leakage Currents as a Function TPC 9. Leakage Currents as a Function of V of V of Temperature D (VS) D (VS) REV. B –7–
