Datasheet ADG608, ADG609 (Analog Devices)
Description | 3 V/5 V, 4/8 Channel High Performance Analog Multiplexers |
Pages / Page | 12 / 1 — 3 V/5 V, 4/8 Channel High. Performance Analog Multiplexers. … |
Revision | A |
File Format / Size | PDF / 165 Kb |
3 V/5 V, 4/8 Channel High. Performance Analog Multiplexers. ADG608/ADG609. FUNCTIONAL BLOCK DIAGRAMS. FEATURES +3 V, +5 V,
a
3 V/5 V, 4/8 Channel High Performance Analog Multiplexers ADG608/ADG609 FUNCTIONAL BLOCK DIAGRAMS FEATURES +3 V, +5 V,
6
5 V Power Supplies V ADG608 ADG609 SS to VDD Analog Signal Range Low On Resistance (30
V
max) S1 S1A Fast Switching Times DA t S4A ON 75 ns max tOFF 45 ns max D Low Power Dissipation (1.5
m
W max) Break-Before-Make Construction S1B ESD > 5000 V as per Military Standard 3015.7 DB S8 S4B TTL and CMOS Compatible Inputs 1 OF 8 1 OF 4 APPLICATIONS DECODER DECODER Automatic Test Equipment Data Acquisition Systems Communication Systems A0 A1 A2 EN A0 A1 EN Avionics and Military Systems Microprocessor Controlled Analog Systems Medical Instrumentation
The ability to operate from single +3 V, +5 V or ± 5 V bipolar
Battery Powered Instruments
supplies makes the ADG608 and ADG609 perfect for use in
Remote Powered Equipment
battery operated instruments and with the new generation of
Compatible with
6
5 V DACs and ADCs such as
DACs and ADCs from Analog Devices. The use of 5 V sup-
AD7840/8, AD7870/1/2/4/5/6/8
plies and reduced operating currents gives much lower power dissipation than devices operating from ± 15 V supplies.
GENERAL DESCRIPTION
The ADG608 and ADG609 are monolithic CMOS analog mul-
PRODUCT HIGHLIGHTS
tiplexers comprising eight single channels and four differential 1. Extended Signal Range channels respectively, fully specified for ± 5 V, +5 V and +3 V The ADG608/ADG609 are fabricated on an enhanced power supplies. The ADG608 switches one of eight inputs to a LC2MOS process giving an increased signal range which common output as determined by the 3-bit binary address lines extends to the supplies. A0, A1 and A2. The ADG609 switches one of four differential 2. Low Power Dissipation inputs to a common differential output as determined by the 2-bit binary address lines A0 and A1. An EN input on both de- 3. Low RON vices is used to enable or disable the device. When disabled, all 4. Fast Switching Times channels are switched OFF. All the address and enable inputs are TTL compatible over the full specified operating tempera- 5. Break-Before-Make Switching ture range, making the parts suitable for bus-controlled systems Switches are guaranteed break-before-make so that input such as data acquisition systems, process controls, avionics and signals are protected against momentary shorting. ATEs since the TTL compatible address inputs simplify the digital 6. Single/Dual Supply Operation interface design and reduce the board space requirements. The ADG608/ADG609 are designed on an enhanced LC2MOS
ORDERING GUIDE
process that provides low power dissipation yet gives high
Model Temperature Range Package Option*
switching speed and low on resistance. Each channel conducts equally well in both directions when ON and has an input signal ADG608BN – 40°C to +85°C N-16 range which extends to the supplies. In the OFF condition, sig- ADG608BR – 40°C to +85°C R-16A nal levels up to the supplies are blocked. All channels exhibit ADG608BRU – 40°C to +85°C RU-16 break-before-make switching action preventing momentary ADG608TRU – 55°C to +125°C RU-16 shorting when switching channels. Inherent in the design is low ADG609BN –40°C to +85°C N-16 charge injection for minimum transients when switching the ADG609BR –40°C to +85°C R-16A digital inputs. ADG609BRU –40°C to +85°C RU-16 *N = Plastic DIP; RU = Thin Shrink Small Outline Package (TSSOP); REV. A R = 0.15" Small Outline IC (SOIC). Information furnished by Analog Devices is believed to be accurate and © Analog Devices, Inc., 1995 reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or
Tel: 617/329-4700 Fax: 617/326-8703
