Datasheet ADG408, ADG409 (Analog Devices)
Description | Datasheet LC2MOS 4-/8-Channel High Performance Analog Multiplexers |
Pages / Page | 15 / 1 — LC2MOS 4-/8-Channel. High Performance Analog Multiplexers. Data Sheet. … |
Revision | D |
File Format / Size | PDF / 259 Kb |
LC2MOS 4-/8-Channel. High Performance Analog Multiplexers. Data Sheet. ADG408/. ADG409. FEATURES. FUNCTIONAL BLOCK DIAGRAMS
LC2MOS 4-/8-Channel High Performance Analog Multiplexers Data Sheet ADG408/ ADG409 FEATURES FUNCTIONAL BLOCK DIAGRAMS 44 V supply maximum ratings ADG408 ADG409 VSS to VDD analog signal range S1 S1A Low on resistance (100 Ω maximum) DA Low power (ISUPPLY < 75 μA) S4A Fast switching D Break-before-make switching action Plug-in replacement for DG408/DG409 S1B DB S8 S4B APPLICATIONS 1-OF-8 1-OF-4 Audio and video routing DECODER DECODER Automatic test equipment
-001
Data acquisition systems A0 A1 A2 EN A0 A1 EN
027 00
Battery-powered systems
Figure 1.
Sample-and-hold systems Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG408/ADG409 are monolithic CMOS analog multiplexers 1. Extended Signal Range. The ADG408/ADG409 are comprising eight single channels and four differential channels, fabricated on an enhanced LC2MOS process, giving an respectively. The ADG408 switches one of eight inputs to a increased signal range that extends to the supply rails. common output as determined by the 3-bit binary address lines 2. Low Power Dissipation. A0, A1, and A2. The ADG409 switches one of four differential inputs to a common differential output, as determined by the 3. Low RON. 2-bit binary address lines A0 and A1. An EN input on both devices 4. Single-Supply Operation. For applications where the is used to enable or disable the device. When the device is disabled, analog signal is unipolar, the ADG408/ADG409 can be all channels are switched off. operated from a single rail power supply. The parts are The ADG408/ADG409 are designed on an enhanced LC2MOS fully specified with a single 12 V power supply and remain process that provides low power dissipation yet gives high functional with single supplies as low as 5 V. switching speed and low on resistance. Each channel conducts equally well in both directions when on and has an input signal range that extends to the supplies. In the off condition, signal levels up to the supplies are blocked. All channels exhibit break-before- make switching action, preventing momentary shorting when switching channels. Inherent in the design is low charge injection for minimum transients when switching the digital inputs. The ADG408/ADG409 are improved replacements for the DG408/DG409 analog multiplexers.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2001–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
