ADG431/ADG432/ADG433120VGVGVVVSDVVSDDD = +15VVSS = –15V VL = +5V100TP-CHANNELTN-CHANNELTP+P+N+N+RRRdBEEE–NNNCCCHHP–N–H80BURIED OXIDE LAYERSUBSTRATE (BACKGATE)OFF ISOLATION60 Figure 1. Trench Isolation APPLICATION40 Figure 2 illustrates a precise, fast sample-and-hold circuit. 1001k10k100k1M10MFREQUENCY – Hz An AD845 is used as the input buffer while the output opera- tional amplifier is an AD711. During the track mode, SW1 is TPC 7. Off Isolation vs. Frequency closed and the output VOUT follows the input signal VIN. In the hold mode, SW1 is opened and the signal is held by the hold capacitor CH. 110 Due to switch and capacitor leakage, the voltage on the hold VDD = +15V capacitor will decrease with time. The ADG431/ADG432/ VSS = –15V100V ADG433 minimizes this droop due to its low leakage specifica- L = +5V tions. The droop rate is further minimized by the use of a polystyrene hold capacitor. The droop rate for the circuit dB –90 shown is typically 30 µV/µs. A second switch SW2, which operates in parallel with SW1, is 80 included in this circuit to reduce pedestal error. Since both CROSSTALK switches will be at the same potential, they will have a differen- tial effect on the op amp AD711 which will minimize charge 70 injection effects. Pedestal error is also reduced by the compensa- tion network RC and CC. This compensation network also reduces the hold time glitch while optimizing the acquisition time. Using 601001k10k100k1M10M the illustrated op amps and component values, the pedestal error FREQUENCY – Hz has a maximum value of 5 mV over the ± 10 V input range. Both TPC 8. Crosstalk vs. Frequency the acquisition and settling times are 850 ns. TRENCH ISOLATION+15V+5V In the ADG431A, ADG432A and ADG433A, an insulating 2200pF oxide layer (trench) is placed between the NMOS and PMOS +15VSW2 transistors of each CMOS switch. Parasitic junctions, which +15VSDC occur between the transistors in junction isolated switches, are RCCVAD711IN1000pFVOUTSW175 eliminated, the result being a completely latch-up proof switch. AD845SDCH–15V In junction isolation, the N and P wells of the PMOS and NMOS 2200pF–15V transistors from a diode that is reverse-biased under normal ADG431 operation. However, during overvoltage conditions, this diode ADG432 ADG433 becomes forward biased. A silicon-controlled rectifier (SCR) type circuit is formed by the two transistors causing a significant –15V amplification of the current which, in turn, leads to latch up. With trench isolation, this diode is removed, the result being a Figure 2. Fast, Accurate Sample-and-Hold latch-up proof switch. –6– REV. C
