Datasheet ADG201S (Analog Devices) - 3
DescriptionHigh Speed Quad SPST CMOS Analog Switch
Pages / Page6 / 3 — :TABLE. I. NOTES:. 1/. V+. =. +15V,. V-. =. -15V,. unless. otherwise. …
RevisionH
File Format / SizePDF / 534 Kb
:TABLE. I. NOTES:. 1/. V+. =. +15V,. V-. =. -15V,. unless. otherwise. specified. 2/. The. limiting. terms. "min". (minimum). and. "max"
:TABLE I NOTES: 1/ V+ = +15V, V- = -15V, unless otherwise specified 2/ The limiting terms "min" (minimum) and "max"
TABLE I NOTES: 1/ V+ = +15V, V- = -15V, unless otherwise specified 2/ The limiting terms "min" (minimum) and "max" (maximum) shall be considered to apply to magnitudes only. Negative current shall be defined as conventional current flow out of a device terminal. 3/ These parameters may not be tested, but shall be guaranteed to the limits specified in table I herein. 4/ Test not required if applied as a forcing function.
