Datasheet ADG701L, ADG702L (Analog Devices) - 9
DescriptionCMOS Low Voltage, 2 Ω SPST Switches
Pages / Page12 / 9 — Data Sheet. ADG701L/ADG702L. TERMINOLOGY RON. tON. RFLAT(ON). tOFF. IS …
RevisionA
File Format / SizePDF / 300 Kb
Data Sheet. ADG701L/ADG702L. TERMINOLOGY RON. tON. RFLAT(ON). tOFF. IS (OFF). Off Isolation. ID (OFF). Charge Injection. D, IS (ON)
Data Sheet ADG701L/ADG702L TERMINOLOGY RON tON RFLAT(ON) tOFF IS (OFF) Off Isolation ID (OFF) Charge Injection D, IS (ON)
link to page 8 link to page 7
Ohmic resistance between D and S. Delay between applying the digital control input and the output switching on. See Figure 16.
RFLAT(ON)
Flatness is defined as the difference between the maximum and
tOFF
minimum value of on resistance as measured over the specified Delay between applying the digital control input and the output analog signal range. switching off.
Source leakage current with the switch off. A measure of unwanted signal coupling through an off switch.
Drain leakage current with the switch off. A measure of the glitch impulse transferred from the digital
I
input to the analog output during switching.
D, IS (ON)
Channel leakage current with the switch on.
Bandwidth V
The frequency at which the output is attenuated by −3 dB.
D (VS)
Analog voltage on Terminal D and Terminal S.
On Response C
The frequency response of the on switch.
S (OFF)
Off switch source capacitance.
On Loss C
The voltage drop across the on switch, seen in Figure 11 as the
D (OFF)
Off switch drain capacitance. number of decibels the signal is away from 0 dB at very low frequencies.
CD, CS (ON)
On switch capacitance. Rev. A | Page 9 of 12 Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Supply Voltages Bandwidth Off Isolation Outline Dimensions Ordering Guide
