Datasheet ADG888 (Analog Devices)
Description | 0.4 Ω CMOS, Dual DPDT Switch in WLCSP/LFCSP/TSSOP |
Pages / Page | 17 / 1 — 0.4 Ω CMOS, Dual DPDT Switch. in WLCSP/LFCSP/TSSOP. Data Sheet. ADG888. … |
Revision | D |
File Format / Size | PDF / 323 Kb |
0.4 Ω CMOS, Dual DPDT Switch. in WLCSP/LFCSP/TSSOP. Data Sheet. ADG888. FEATURES. FUNCTIONAL BLOCK DIAGRAM
0.4 Ω CMOS, Dual DPDT Switch in WLCSP/LFCSP/TSSOP Data Sheet ADG888 FEATURES FUNCTIONAL BLOCK DIAGRAM 1.8 V to 5.5 V operation ADG888 Ultralow on resistance S1A 0.4 Ω typical D1 0.6 Ω maximum at 5 V supply S1B Excellent audio performance, ultralow distortion S2A 0.07 Ω typical D2 0.14 Ω maximum R S2B ON flatness High current carrying capability IN1 400 mA continuous 600 mA peak current at 5 V S3A D3 Automotive temperature range: −40°C to +125°C S3B Rail-to-rail switching operation Typical power consumption (<0.1 μW) S4A D4 APPLICATIONS S4B Cellular phones IN2 PDAs
01 0
MP3 players
2-
SWITCHES SHOWN
43
FOR A LOGIC 1 INPUT
05
Power routing
Figure 1.
Battery-powered systems PCMCIA cards Modems Audio and video signal routing Communication systems Data switching GENERAL DESCRIPTION
The ADG888 is a low voltage, dual DPDT (double-pole, The ADG888 is available in a 16-ball WLCSP, 16-lead LFCSP, double-throw) CMOS device optimized for high performance and a 16-lead TSSOP. These packages make the ADG888 the audio switching. With its low power and small physical size, it is ideal solution for space-constrained applications. ideal for portable devices.
PRODUCT HIGHLIGHTS
This device offers ultralow on resistance of less than 0.8 Ω over 1. <0.6 Ω over full temperature range of −40°C to +125°C. the full temperature range, making it an ideal solution for 2. High current handling capability (400 mA continuous applications requiring minimal distortion through the switch. current at 5 V). The ADG888 also has the capability of carrying large amounts 3. Low THD + N (0.008% typical). of current, typically 400 mA at 5 V operation. 4. Tiny 16-ball WLCSP, 16-lead LFCSP, and 16-lead TSSOP. When on, each switch conducts equally well in both directions and has an input signal range that extends to the supplies. The ADG888 exhibits break-before-make switching action.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2005–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
