Datasheet ADG841-KGD (Analog Devices)
Description | 0.28 Ω, CMOS, 1.65 V to 3.6 V, Single SPST Switch |
Pages / Page | 9 / 1 — 0.28 Ω, CMOS, 1.65 V to 3.6 V,. Single SPST Switch. Known Good Die. … |
Revision | B |
File Format / Size | PDF / 285 Kb |
0.28 Ω, CMOS, 1.65 V to 3.6 V,. Single SPST Switch. Known Good Die. ADG841-KGD. FEATURES. FUNCTIONAL BLOCK DIAGRAM
0.28 Ω, CMOS, 1.65 V to 3.6 V, Single SPST Switch Known Good Die ADG841-KGD FEATURES FUNCTIONAL BLOCK DIAGRAM Ultralow on resistance ADG841-KGD 0.28 Ω typical 0.48 Ω max at 125°C S D Excellent audio performance, ultralow distortion 0.025 Ω typical 0.052 Ω max RON flatness IN 1.65 V to 3.6 V single supply
1
High current carrying capability
00
SWITCH SHOWN
66-
300 mA continuous current FOR A LOGIC 1 INPUT
102 Figure 1.
500 mA peak current Automotive temperature range: −40°C to +125°C Rail-to-rail operation Typical power consumption (<0.01 μW) Known good die (KGD): these die are fully guaranteed to data sheet specifications APPLICATIONS Handsets PDAs MP3 players Power routing Battery-powered systems Communication systems Modems PCMCIA cards GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG841-KGD is a low voltage CMOS device containing a 1. <0.48 Ω over full temperature range of −40°C to +125°C. single-pole, single-throw (SPST) switch. The ADG841-KGD 2. Compatible with 1.8 V CMOS logic. is closed for a Logic 1 input. The device offers ultralow on 3. High current handling capability resistance of less than 0.48 Ω over the full temperature range. (300 mA continuous current at 3.3 V). The ADG841-KGD is fully specified for 3.3 V, 2.5 V, and 1.8 V 4. Low THD + N (0.02% typical). supply operation.
Table 1. ADG841-KGD Truth Table
Each switch conducts equally well in both directions when on,
Logic (IN) ADG841-KGD
and has an input signal range that extends to the supplies. 0 Off Additional application and technical information can be found 1 On in the ADG841 data sheet.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS—2.7 V TO 3.6 V SPECIFICATIONS—2.5 V ± 0.2 V SPECIFICATIONS—1.65 V TO 1.95 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
