Datasheet MAX4173 (Maxim) - 3
ManufacturerMaxim
DescriptionLow-Cost, SOT23, Voltage-Output, High-Side Current-Sense Amplifier
Pages / Page10 / 3 — Low-Cost, SOT23, Voltage-Output,. High-Side Current-Sense Amplifier. …
File Format / SizePDF / 497 Kb
Low-Cost, SOT23, Voltage-Output,. High-Side Current-Sense Amplifier. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL
Low-Cost, SOT23, Voltage-Output, High-Side Current-Sense Amplifier ELECTRICAL CHARACTERISTICS (continued) PARAMETER SYMBOL
MAX4173
(VRS+ = 0 to +28V, VCC = +3V to +28V, VSENSE = 0V, TA = TMIN to TMAX, RLOAD = ∞ unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX4173T, 1.7 VSENSE = +100mV MAX4173F, 1.4 VRS+ = +12V, VSENSE = +100mV Bandwidth BW VCC = +12V, MHz MAX4173H, CLOAD = 5pF 1.2 VSENSE = +100mV VSENSE = +6.25mV 0.6 (Note 4) MAX4173T 20 Gain AV MAX4173F 50 V/V MAX4173H 100 MAX4173T/F VSENSE = TA = +25°C 0.5 ±2.5 ∆AV +10mV to +150mV, VCC = VRS+ = 12V TA = -40°C to +85°C 4.0 Gain Accuracy % MAX4173H VSENSE = TA = +25°C 0.5 ±2.5 ∆AV +10mV to +100mV, VCC = VRS+ = 12V TA = -40°C to +85°C 4.0 Input Offset Voltage MAX4173TEUT, TA = +25°C 0.3 ±3 VOS mV (Note 6) VRS+ = 12V TA = -40°C to +85°C ±5 VSENSE = +6.25mV 400 to +100mV OUT Settling Time to 1% of VCC = +12V, VRS+ = 12V, ns Final Value CLOAD = 5pF VSENSE = +100mV 800 to +6.25mV OUT Output Resistance ROUT 12 kΩ MAX4173T, VSENSE = 80mV, VRS+ ≥ +2V 60 84 Power-Supply Rejection PSR MAX4173F, VSENSE = 32mV, VRS+ ≥ +2V 60 91 dB MAX4173H, VSENSE = 16mV, VRS+ ≥ +2V 60 95 Power-Up Time to 1% of VSENSE = +100mV, CLOAD = 5pF 10 µs Final Value Saturation Recovery Time VCC = +12V, VRS+ = 12V (Note 7) 10 µs
Note 1:
All devices are 100% production tested at TA = +25°C. All temperature limits are guaranteed by design.
Note 2:
Guaranteed by Total Output Voltage Error Test.
Note 3:
Total OUT Voltage Error is the sum of gain and offset voltage errors.
Note 4:
+6.25mV = 1/16 of +100mV full-scale voltage.
Note 5:
VSENSE such that output stage is in saturation.
Note 6:
VOS is extrapolated from the Gain Accuracy tests.
Note 7:
The device does not experience phase reversal when overdriven. Maxim Integrated 3
