Datasheet A1321, A1322, A1323 (Allegro) - 3
ManufacturerAllegro
DescriptionRatiometric Linear Hall Effect Sensor ICs for High-Temperature Operation
Pages / Page13 / 3 — A1321, A1322,. Ratiometric Linear Hall Effect Sensor ICs. and A1323. for …
File Format / SizePDF / 528 Kb
A1321, A1322,. Ratiometric Linear Hall Effect Sensor ICs. and A1323. for High-Temperature Operation. Description (continued)
A1321, A1322, Ratiometric Linear Hall Effect Sensor ICs and A1323 for High-Temperature Operation Description (continued)
recoverability after temperature cycling. Having the Hall element The A132X family is provided in a 3-pin single in-line package and an amplifier on a single chip minimizes many problems normally (UA) and a 3-pin surface mount package (LH). Each package is associated with low-level analog signals. available in a lead (Pb) free version (suffix, –T) , with a 100% matte tin plated leadframe. Output precision is obtained by internal gain and offset trim adjustments made at end-of-line during the manufacturing process.
Selection Guide Ambient, T Sensitivity, Part Number Packing1 Mounting A (ºC) Typ. (mV/G)
A1321ELHLT-T2 7-in. reel, 3000 pieces/reel Surface Mount –40 to 85 A1321EUA-T3 Bulk, 500 pieces/bag SIP through hole 5.000 A1321LLHLT-T2 7-in. reel, 3000 pieces/reel Surface Mount –40 to 150 A1321LUA-T3 Bulk, 500 pieces/bag SIP through hole A1322LLHLT-T2 7-in. reel, 3000 pieces/reel Surface Mount –40 to 150 3.125 A1322LUA-T3 Bulk, 500 pieces/bag SIP through hole A1323EUA-T3 Bulk, 500 pieces/bag SIP through hole –40 to 85 A1323LLHLT-T2 7-in. reel, 3000 pieces/reel Surface Mount 2.500 –40 to 150 A1323LUA-T3 Bulk, 500 pieces/bag SIP through hole 1Contact Allegro for additional packing options. 2This variant is in production, however, it has been deemed Pre-End of Life. The product is approaching end of life. Within a minimum of 6 months, the device will enter its final, Last Time Buy, order phase. Status change: January 31, 2011. Suggested replacements: for the A1321ELHLT-T and the A1321LLHLT-T use the A1324LLHLX-T, for the A1322LLHLT-T use the A1325LLHLX-T, and for the A1323LLHLT-T use the A1326LLHLX-T. 3Variant is in production but has been determined to be NOT FOR NEW DESIGN. This classification indicates that sale of the variant is currently restricted to existing customer applications. The variant should not be purchased for new design applications because obsolescence in the near future is probable. Samples are no longer available. Status change: January 31, 2011.
Absolute Maximum Ratings Characteristic Symbol Notes Rating Units
*Additional current draw may be observed at voltages above the minimum supply Zener Supply Voltage VCC 8 V clamp voltage, VZ(min), due to the Zener diode turning on. Output Voltage VOUT 8 V Reverse Supply Voltage VRCC –0.1 V Reverse Output Voltage VROUT –0.1 V Output Sink Current IOUT 10 mA Operating Ambient Temperature TA Range L –40 to 150 ºC Maximum Junction Temperature TJ(max) 165 ºC Storage Temperature Tstg –65 to 170 ºC Allegro MicroSystems, Inc. 2 115 Northeast Cutoff Worcester, Massachusetts 01615-0036 U.S.A. 1.508.853.5000; www.allegromicro.com
