Datasheet BAV199 (Nexperia)
Manufacturer | Nexperia |
Description | Low-leakage double diode |
Pages / Page | 10 / 1 — BAV199. Low-leakage double diode. 1 September 2020. Product data sheet. … |
Revision | 01092020 |
File Format / Size | PDF / 209 Kb |
BAV199. Low-leakage double diode. 1 September 2020. Product data sheet. 1. General description. 2. Features and benefits
BAV199 Low-leakage double diode 1 September 2020 Product data sheet 1. General description
Epitaxial, medium-speed switching, double diode in a small SOT23 plastic SMD package. The diodes are connected in series.
• Plastic SMD package • Low leakage current: typ. 3 pA • Switching time: typ. 0.8 us • Continuous reverse voltage: max. 75 V • Repetitive peak reverse voltage: max. 85 V • Repetitive peak forward current: max. 500 mA. • AEC-Q101 qualified
3. Applications
• Low-leakage current applications in surface mounted circuits.
4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit Per diode
VR reverse voltage - - 75 V IR reverse current VR = 75 V; Tj = 150 °C - 3 80 nA
5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline Graphic symbol
1 A1 anode (diode 1) 3 K1, A2 2 K2 cathode (diode 2) 3 K1, A2 cathode (diode 1) and anode (diode 2) 1 2 A1 K2
SOT23
006aaa763 Document Outline 1. General description 2. Features and benefits 3. Applications 4. Quick reference data 5. Pinning information 6. Ordering information 7. Marking 8. Limiting values 9. Thermal characteristics 10. Characteristics 11. Test information 12. Package outline 13. Soldering 14. Revision history 15. Legal information Contents
