Datasheet MAX9691, MAX9692, MAX9693 (Maxim) - 2
ManufacturerMaxim
DescriptionSingle/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable
Pages / Page12 / 2 — Single/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable. …
File Format / SizePDF / 328 Kb
Single/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable. ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS
Single/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS
Supply Voltage (VCC) ...-0.3V to +6V 8-Pin PDIP (derate 9.1mW/°C above +70°C) ...727.3mW Supply Voltage (VEE)..-6V to +0.3V 10-Pin µMAX (derate 8.8mW/°C above +70°C) ...707.3mW Input Voltage..(VCC + 0.3V) to (VEE - 0.3V) 16-Pin QSOP (derate 9.6mW/°C above +70°C) ...771.5mW Output Short-Circuit Duration ..Continuous 16-Pin SO (derate 13.3mW/°C above +70°C) ..1066.7mW Differential Input Voltage ..±5V 16-Pin PDIP (derate 10.5mW/°C above +70°C) ...842.1mW Latch Enable ...(VEE - 0.3V) to +0.3V Operating Temperature Range ...-40°C to +85°C Output Current ..50mA Junction Temperature ..+150°C Input Current ..±25mA Storage Temperature Range ...-55°C to +150°C Continuous Power Dissipation (TA = +70°C) Lead Temperature (soldering, 10s) ...+300°C 8-Pin µMAX (derate 4.8mW/°C above 70°C)...387.8mW Soldering Temperature (reflow) ...+260°C 8-Pin SO (derate 7.4mW/°C above +70°C)..588.2mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(VCC = +5V, VEE = -5.2V, RL = 50Ω to VT, VT = -2V, LE = 0, TA = TMIN to TMAX, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
TA = +25°C -6.5 6.5 Input Offset Voltage VOS mV TA = T MIN to TMAX -11.5 +11.5 Temperature Coefficient ∆VOS/∆T 10 µV/°C TA = +25°C 0.2 5 Input Offset Current IOS µA TA = T MIN to TMAX 8 TA = +25°C 6 20 Input Bias Current IB µA TA = T MIN to TMAX 30
MAX9691/MAX9692/MAX9693
Input Voltage Range VCM Note 1 -2.5 +3.0 V Common-Mode Rejection Ratio CMRR -2.5V ≤ VCM ≤ +3.0V (Note 1) 60 80 dB Positive Power-Supply Rejection +PSRR 4.5V ≤ VCC ≤ 5.5V 60 dB Ratio Negative Power-Supply -PSRR -5.7V ≤ VEE ≤ -4.7V 60 dB Rejection Ratio Open-Loop Gain AOL VCM = 0V 70 dB Differential Input Resistance RIN -10mV < VIN < 10mV 60 kΩ Differential Input Clamp Voltage 1.7 V Input Capacitance CIN 3 pF Latch Enable Input Current High IIH(LE) VIH(LE) = 1.1V 60 120 µA Latch Enable Input Current Low IIL(LE) VIL(LE) = 1.5V 0.2 10 µA Latch E nab l e Log i c H i g h V ol tag e VIH(LE) -1.1 V Latch Enable Logic Low Voltage VIL(LE) -1.5 V TA = TMIN -1.2 -0.87 Logic Output High Voltage VOH TA = TMAX -0.99 -0.70 V TA = +25°C -1.06 -0.76 TA = TMIN -1.93 -1.57 TA = TMAX -1.89 -1.51 Logic Output Low Voltage VOL V TA = +25°C -1.89 -1.55
2 _______________________________________________________________________________________
