Datasheet DO5010H (Coilcraft)
Manufacturer | Coilcraft |
Description | SMT Power Inductors |
Pages / Page | 2 / 1 — SMT Power Inductors - DO5010H Series. Designer’s Kit C355. Core material. … |
File Format / Size | PDF / 249 Kb |
SMT Power Inductors - DO5010H Series. Designer’s Kit C355. Core material. Core and winding loss. Terminations. Weight
Document 284-1
AEC • Irms ratings up to 15 A; saturation currents up to 30 A Q200 85 + °C • Heavy gauge wire for low DC resistance
Designer’s Kit C355
contains 3 of each part
Core material
Ferrite
See www.coilcraft.com/coreloss
Terminations
RoHS compliant tin-silver over copper. Other terminations available at additional cost.
Weight
3.2 – 4.0 g
Ambient temperature
–40°C to +85°C with Irms current, +85°C to +125°C with derated current
Storage temperature
Component: –40°C to +125°C. Tape and reel packaging: –40°C to +80°C
Resistance to soldering heat
Max three 40 second reflows at +260°C, parts cooled to room temperature between cycles
Moisture Sensitivity Level (MSL)
1 (unlimited floor life at <30°C / 85% relative humidity)
Packaging
250 per 13″ reel Plastic tape: 32 mm wide, 0.38 mm thick, 24 mm pocket spacing, 7.8 mm pocket depth
PCB washing
Tested to MIL-STD-202 Method 215 plus an additional aqueous wash. See Doc787_PCB_Washing.pdf.
DCR SRF
1. When ordering, please specify
termination
and
packaging
codes:
Inductance
2
max typ
3
Isat
4
Irms
5
Part Number
1
±20% (µH) (mOhm) (MHz) (A) (A) DO5010H-105MLD
DO5010H-781ML_ 0.78 2.6 156 30 15
Termination: L
= RoHS compliant tin-silver over copper. DO5010H-152ML_ 1.5 4.0 100 25 15
Special order: T
= RoHS tin-silver-copper DO5010H-222ML_ 2.2 6.1 75 20 12 (95.5/4/0.5) or
S
= non-RoHS tin-lead (63/37). DO5010H-332ML_ 3.3 8.6 60 17 10
Packaging: D
= 13″ machine-ready reel. EIA-481 embossed plastic tape. Quantities less than full reel available: in tape DO5010H-392ML_ 3.9 10 55 15 9.0 (not machine ready) or with leader and trailer ($25 DO5010H-472ML_ 4.7 14 40 13 8.4 charge). DO5010H-602ML_ 6.0 17 35 12 7.5
B
= Less than full reel. In an effort to simplify our part DO5010H-782ML_ 7.8 18 35 11 7.5 numbering system, Coilcraft is eliminating the need DO5010H-103ML_ 10 26 28 10 6.0 for multiple packaging codes. When ordering, simply DO5010H-123ML_ 12 28 26 8.5 5.2 change the last letter of your part number from B to D. 2. Inductance tested at 100 kHz, 0.1 Vrms using an Agilent/HP 4284A DO5010H-153ML_ 15 32 20 8.0 4.4 LCR meter or equivalent. DO5010H-223ML_ 22 47 20 7.0 3.5 3. SRF measured using Agilent/HP 8753D network analyzer. DO5010H-333ML_ 33 66 15 5.5 3.0 4. DC current at which the inductance drops 10% (typ) from its value DO5010H-473ML_ 47 86 9 4.5 2.6 without current. DO5010H-683ML_ 68 130 8 3.5 2.3 5. Current that causes a 40°C temperature rise from 25°C ambient. DO5010H-104ML_ 100 190 7 3.0 1.8 6. Electrical specifications at 25°C. DO5010H-154ML_ 150 250 6 2.6 1.5 Refer to Doc 362 “Soldering Surface Mount Components” before soldering. DO5010H-224ML_ 220 380 5 2.4 1.2 DO5010H-334ML_ 330 560 4 1.9 1.0 DO5010H-474ML_ 470 850 3 1.4 0.82 DO5010H-684ML_ 680 1100 2.5 1.2 0.72 DO5010H-105ML_ 1000 1800 2.0 1.0 0.56
US
+1-847-639-6400 sales@coilcraft.com Document 284-1 Revised 12/29/21
UK
+44-1236-730595 sales@coilcraft-europe.com © Coilcraft Inc. 2021
Taiwan
+886-2-2264 3646 sales@coilcraft.com.tw This product may not be used in medical or high
China
+86-21-6218 8074 sales@coilcraft.com.cn risk applications without prior Coilcraft approval. Specification subject to change without notice.
Singapore
+ 65-6484 8412 sales@coilcraft.com.sg Please check web site for latest information.
