Datasheet MAX987, MAX988, MAX991, MAX992, MAX995, MAX996 (Maxim) - 3
ManufacturerMaxim
DescriptionHigh-Speed, Micropower, Low-Voltage, Rail-to-Rail I/O Comparators
Pages / Page13 / 3 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:. Note 2:. Note 3:. Note 4:
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Note 1: Note 2: Note 3: Note 4:
MAX987/MAX988/MAX991/ High-Speed, Micropower, Low-Voltage, MAX992/MAX995/MAX996 Rail-to-Rail I/O Comparators
(VCC = +2.7V to +5.5V, VEE = 0V, VCM = 0V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C.)
OUT Rise Time CL = 15pF 15 (MAX987/MAX991/ tRISE VCC = 5.0V CL = 50pF 20 ns MAX995 Only) CL = 200pF 40 CL = 15pF 15 OUT Fall Time tFALL VCC = 5.0V CL = 50pF 20 ns CL = 200pF 40 MAX987/MAX991/ 10mV overdrive 210 MAX995 only 100mV overdrive 120 t CL = 15pF, PD- VCC = 5V MAX988/MAX992/ 10mV overdrive 210 Propagation Delay MAX996 only, ns RPULLUP = 5.1kΩ 100mV overdrive 120 10mV overdrive 210 t MAX987/MAX991/MAX995 PD+ only, CL = 15pF, VCC = 5V 100mV overdrive 120 Power-Up Time tPU 25 µs
Note 1:
All device specifications are 100% production tested at TA = +25°C. Limits over the extended temperature range are guaranteed by design, not production tested.
Note 2:
Inferred from the VOS test. Either or both inputs can be driven 0.3V beyond either supply rail without output phase reversal.
Note 3:
VOS is defined as the center of the hysteresis band at the input.
Note 4:
IB is defined as the average of the two input bias currents (IB-, IB+). www.maximintegrated.com Maxim Integrated │ 3
