DatasheetsDatasheet RFD10P03L, RFD10P03LSM, RFP10P03L …
Datasheet RFD10P03L, RFD10P03LSM, RFP10P03L (Intersil)
Manufacturer | Intersil |
Description | 10A, 30V, 0.200 Ohm, Logic Level, P-Channel Power MOSFET |
Pages / Page | 8 / 1 — RFD10P03L, RFD10P03LSM, RFP10P03L. Data Sheet. July 1999. File Number. … |
File Format / Size | PDF / 145 Kb |
RFD10P03L, RFD10P03LSM, RFP10P03L. Data Sheet. July 1999. File Number. 3515.2. 10A, 30V, 0.200 Ohm, Logic Level,. Features
RFD10P03L, RFD10P03LSM, RFP10P03L Data Sheet July 1999 File Number 3515.2 10A, 30V, 0.200 Ohm, Logic Level, Features P-Channel Power MOSFET
• 10A, 30V These products are P-Channel power MOSFETs • rDS(ON) = 0.200Ω manufactured using the MegaFET process. This process, which uses feature sizes approaching those of LSI circuits, • Temperature Compensating PSPICE® Model gives optimum utilization of silicon, resulting in outstanding • PSPICE Thermal Model performance. They were designed for use in applications such as switching regulators, switching converters, motor • Peak Current vs Pulse Width Curve drivers, and relay drivers. These transistors can be operated • UIS Rating Curve directly from integrated circuits. • 175oC Operating Temperature Formerly developmental type TA49205.
Symbol Ordering Information D PART NUMBER PACKAGE BRAND
RFD10P03L TO-251AA 10P03L
G
RFD10P03LSM TO-252AA 10P03L RFP10P03L TO-220AB F10P03L
S
NOTE: When ordering, use the entire part number. Add the suffix, 9A, to obtain the TO-252AA variant in tape and reel, i.e. RFD10P03LSM9A..
Packaging JEDEC TO-251AA JEDEC TO-252AA DRAIN (FLANGE) SOURCE DRAIN DRAIN (FLANGE) GATE GATE SOURCE JEDEC TO-220AB SOURCE DRAIN GATE DRAIN (FLANGE)
7-3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper ESD Handling Procedures. PSPICE® is a registered trademark of MicroSim Corporation. http://www.intersil.com or 407-727-9207 | Copyright © Intersil Corporation 1999
