Datasheet IRLR8743PbF, IRLU8743PbF (Infineon) - 7
Manufacturer | Infineon |
Description | HEXFET Power MOSFET |
Pages / Page | 12 / 7 — D.U.T. Fig 15. Fig 16 |
Revision | 01_01 |
File Format / Size | PDF / 387 Kb |
IRLR/U8743PbF Driver Gate Drive P.W.
D.U.T
Period D = P.W. Period + V * Circuit Layout Considerations GS=10V • Low Stray Inductance • Ground Plane - • Low Leakage Inductance D.U.T. I Current Transformer SD Waveform + Reverse Recovery Body Diode Forward Current Current - + - di/dt D.U.T. VDS Waveform Diode Recovery dv/dt VDD • dv/dt controlled by R V G DD Re-Applied RG + Voltage • Driver same type as D.U.T. Body Diode Forward Drop • ISD controlled by Duty Factor "D" - Inductor Curent • D.U.T. - Device Under Test Ripple ≤ 5% ISD * VGS = 5V for Logic Level Devices
Fig 15.
Peak Diode Recovery dv/dt Test Circuit for N-Channel HEXFET® Power MOSFETs Id Vds Vgs Vgs(th) Qgodr Qgd Qgs2 Qgs1
Fig 16.
Gate Charge Waveform www.irf.com 7
