Datasheet TMP35, TMP36, TMP37 (Analog Devices) - 5
DescriptionLow Voltage Temperature Sensors
Pages / Page19 / 5 — Data Sheet. TMP35/TMP36/TMP37. TYPICAL PERFORMANCE CHARACTERISTICS. 0.4. …
File Format / SizePDF / 456 Kb
Data Sheet. TMP35/TMP36/TMP37. TYPICAL PERFORMANCE CHARACTERISTICS. 0.4. +VS = 3V TO 5.5V, NO LOAD. /V). A) µ. 0.3. N IO. N (. 0.2. Y R. UL G
Data Sheet TMP35/TMP36/TMP37 TYPICAL PERFORMANCE CHARACTERISTICS 0.4 +VS = 3V TO 5.5V, NO LOAD /V) A) µ 0.3 N IO N ( 0.2 Y R UL G
Data Sheet TMP35/TMP36/TMP37 TYPICAL PERFORMANCE CHARACTERISTICS 50 0.4 +VS = 3V TO 5.5V, NO LOAD /V) 40 C A) µ 0.3 C/ N IO T N ( 30 EC IO EJ AT 0.2 Y R UL G 20 PPL SU AD RE ER O 0.1 L W 10 PO
005 009
0
00337-
0
00337-
–50 0 50 100 150 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 5. Load Regulation vs. Temperature (m°C/µA) Figure 8. Power Supply Rejection vs. Temperature
2.0 100.000 a. TMP35 1.8 b. TMP36 c. TMP37 31.600 +V c 1.6 S = 3V C/V)
) 10.000 V 1.4 ( b GE 1.2 3.160 OLTA 1.0 1.000 T V U 0.8 a TP 0.320 0.6 OU 0.100 0.4 POWER SUPPLY REJECTION ( 0.2 0.032
007
0
00337-
0.010
00337-010
–50 –25 0 25 50 75 100 125 20 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz)
Figure 6. Output Voltage vs. Temperature Figure 9. Power Supply Rejection vs. Frequency
5 5 4 MINIMUM SUPPLY VOLTAGE REQUIRED TO MEET 3 4 DATA SHEET SPECIFICATION a a. MAXIMUM LIMIT (G GRADE)
C) 2 NO LOAD b. TYPICAL ACCURACY ERROR c. MINIMUM LIMIT (G GRADE) 1 3 0 b –1 2 b a –2 ACCURACY ERROR ( –3 MINIMUM SUPPLY VOLTAGE (V) 1 a. TMP35/TMP36 –4 b. TMP37 c –5
00337-008
0
00337-011
0 20 40 60 80 100 120 140 –50 –25 0 25 50 75 100 125 TEMPERATURE (
C) TEMPERATURE (
C)
Figure 7. Accuracy Error vs. Temperature Figure 10. Minimum Supply Voltage vs. Temperature Rev. H | Page 5 of 19
