Datasheet ADP3623, ADP3624, ADP3625, ADP3633, ADP3634, ADP3635 (Analog Devices) - 8
DescriptionHigh Speed, Dual, 4 A MOSFET Driver with Thermal Protection
Pages / Page16 / 8 — ADP3623/ADP3624/ADP3625/ADP3633/ADP3634/ADP3635. OTW. ADP3625/. INA 2. …
File Format / SizePDF / 317 Kb
ADP3623/ADP3624/ADP3625/ADP3633/ADP3634/ADP3635. OTW. ADP3625/. INA 2. OUTA. ADP3635. PGND. TOP VIEW. VDD. INB. (Not to Scale). OUTB
ADP3623/ADP3624/ADP3625/ADP3633/ADP3634/ADP3635 OTW ADP3625/ INA 2 OUTA ADP3635 PGND TOP VIEW VDD INB (Not to Scale) OUTB
ADP3623/ADP3624/ADP3625/ADP3633/ADP3634/ADP3635 SD 1 8 OTW ADP3625/ INA 2 7 OUTA ADP3635 PGND 3 6 TOP VIEW VDD INB (Not to Scale) 4 5 OUTB NOTES 1. THE EXPOSED PAD OF THE PACKAGE IS NOT DIRECTLY CONNECTED TO ANY PIN OF THE PACKAGE, BUT IT IS ELECTRICALLY AND THERMALLY CONNECTED TO THE DIE
009
SUBSTRATE, WHICH IS THE GROUND OF THE DEVICE.
08132- Figure 9. ADP3625/ADP3635 Pin Configuration
Table 5. ADP3625/ADP3635 Pin Function Descriptions Pin No. Mnemonic Description
1 SD Output Shutdown. When high, this pin disables normal operation, forcing OUTA and OUTB low. 2 INA Inverting Input Pin for Channel A Gate Driver. 3 PGND Ground. This pin should be closely connected to the source of the power MOSFET. 4 INB Input Pin for Channel B Gate Driver. 5 OUTB Output Pin for Channel B Gate Driver. 6 VDD Power Supply Voltage. Bypass this pin to PGND with a ~1 µF to 5 µF ceramic capacitor. 7 OUTA Output Pin for Channel A Gate Driver. 8 OTW Overtemperature Warning Flag. Open drain, active low. Rev. A | Page 8 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuit Theory of Operation Input Drive Requirements (INA, AA, INB, AA, and SD) Low-Side Drivers (OUTA, OUTB) Shutdown (SD) Function Overtemperature Protections Supply Capacitor Selection PCB Layout Considerations Parallel Operation Thermal Considerations Design Example Outline Dimensions Ordering Guide
