Datasheet MTP3N60E (ON Semiconductor) - 7
ManufacturerON Semiconductor
DescriptionTMOS E−FET High Energy Power FET N−Channel Enhancement−Mode Silicon Gate
Pages / Page9 / 7 — MTP3N60E. Figure 13. Commutating Safe Operating Area. Test Circuit. …
File Format / SizePDF / 292 Kb
MTP3N60E. Figure 13. Commutating Safe Operating Area. Test Circuit. Figure 10. Thermal Response
MTP3N60E Figure 13 Commutating Safe Operating Area Test Circuit Figure 10 Thermal Response
MTP3N60E
RGS DUT
MTP3N60E
− 1 4 VR D = 0.5 0.5 + I + FM IS Li ANCE 0.3 + VDS 0.2 3 RESIST 0.2 20 V (AMPS) 0.1 − V 0.1 GSP(pk) RθJC(t) = r(t) RθJC 0.05 2 THERMAL RθJC = 1.67°C/W MAX V 0.05 R D CUR = 80% OF RA VES APPL TED VDS Y FOR POWER 0.02 di/dt , NORMALIZED EFFECTIVE ≤ 60 A/μs VdsL = Vf + Li ⋅ dls/dt PULSE TRAIN SHOWN t1 r(t) 0.03 READ TIME AT t1 , DRAIN CURRENT t2 I D 1 TRANSIENT 0.02 0.01
TJ(pk) − TC = P(pk) RθJC(t) DUTY CYCLE, D = t1/t2 SINGLE PULSE
Test Circuit
0.01 0.01 0.02 0.05 0.1 0.2 0.5 1 2 5 10 20 50 100 200 500 1 0 0 200 400 600 800 t, TIME (ms) VDS, DRAIN-TO-SOURCE VOLTAGE (VOLTS) V(BR)DSS
Figure 10. Thermal Response Figure 12. Commutating Safe Operating Area (CSOA)
Vds(t)
COMMUTATING SAFE OPERATING AREA (CSOA)
IO 15 V The Commutating Safe Operating Area (CSOA) of Figure V 12 defines the limits of safe GS L operation for commutated 0 I source-drain current versus re-applied drain voltage when D(t) V I DS C FM dl 4700 μF the source-drain diode has undergone forward bias. The S/dt 90% ID curve shows the limitations of IFM and peak V 250 V R for a given I commutation speed. It is applicable when waveforms S t V rr DD similar to those of Figure 11 are present. Full or half-bridge 10% VDD PWM DC motor controllers are common applications ton I t requiring CSOA data. RM tP t, (TIME) The time interval t 0.25 I R RM frr is GS the speed of the commutation t cycle. frr 50 Ω Device stresses increase with commutation speed, V ǒ V(BR)DSS Ǔ WDSR + ǒ1 LI 2 O2Ǔ V DS(pk) (BR)DSS–VDD so tfrr is specified with a minimum value. Faster
Figure 14. Unclamped Inductive Switching
commutation speeds require an appropriate derating of IFM,
Figure 15. Unclamped Inductive Switching
VR peak VR
T
or both. Ultimately,
est Circuit
tfrr is limited primarily by device,
Waveforms
package, and circuit impedances. Maximum device stress VDS occurs during t V rr as the diode goes from conduction to V dsL f reverse blocking. VDS(pk) is the peak drain−to−source voltage that the MAX. CSOA device must sustain during commutation; IFM is the STRESS AREA maximum forward source-drain diode current just prior to the onset of commutation.
Figure 11. Commutating Waveforms
VR is specified at 80% of V(BR)DSS to ensure that the CSOA stress is maximized as IS decays from IRM to zero. RGS should be minimized during commutation. TJ has only a second order effect on CSOA. Stray inductances, Li in Motorola’s test circuit are assumed to be practical minimums.
http://onsemi.com 6
