Datasheet TSV782 (STMicroelectronics) - 5
Manufacturer | STMicroelectronics |
Description | High bandwidth (30 MHz) low offset (200 µV) rail-to-rail 5 V op amp |
Pages / Page | 31 / 5 — TSV782. Electrical characteristics. Symbol. Parameter. Conditions. Min. … |
File Format / Size | PDF / 8.4 Mb |
TSV782. Electrical characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. DS14011. Rev 2. page 5/31
TSV782 Electrical characteristics Symbol Parameter Conditions Min. Typ. Max. Unit
SR Slew rate RL = 10 kΩ, AV = 1 V/V, 10% to 90% 17 20 V/µs trec Overload recovery time VOUT = 100 mV from rail, AV = +1 V/V 170 ns VOUT = 4 Vpp, RL = 10 kΩ, AV = +101 V/V, CR Cross talk 120 dB f = 1 kHz Φm Phase margin 47 degrees GM Gain margin 9 dB f = 10 kHz 7 en Input voltage noise density nV/√Hz f = 1 kHz 14 en p-p Input noise voltage 0.1 Hz ≤ f ≤ 10 Hz 9 µVpp Differential 6.3 Cin Input capacitance pF Common mode 1.6
DS14011
Rev 2 page 5/31
Document Outline Features Applications Description 1 Pin description 1.1 TSV782 dual operational amplifier 2 Absolute maximum ratings and operating conditions 3 Electrical characteristics 4 Typical performance characteristics 5 Application information 5.1 Operating voltages 5.2 Input offset voltage drift over the temperature 5.3 Long term input offset voltage drift 5.4 Unused channel 5.5 EMI rejection 5.6 Maximum power dissipation 5.7 Capacitive load and stability 5.8 Resistor values for high speed op amp design 5.9 PCB layout recommendations 5.10 Decoupling capacitor 5.11 Macromodel 6 Typical applications 6.1 Low-side current sensing 6.2 Photodiode transimpedance amplification 7 Package information 7.1 DFN8 2x2 package information 7.2 MiniSO8 package information 7.3 SO8 package information 8 Ordering information Revision history
